Xf a/c issues
Old Feb 17, 2019 | 10:36 PM
swonkeXF's Avatar
Default Xf a/c issues
My 2009 Jaguar XF is having a problem where the AC won't blow out of the center two vents. All of the other vents seem to be working just fine, the footwell vents might even be blowing more than normal. If this is something I can DIY fix, does anyone know the steps to doing so? If not, has anyone else had this problem repaired and know what it would cost to fix?
Old Feb 17, 2019 | 11:09 PM
davetibbs's Avatar
At a guess, one of the stepper motors that control the flow of air is misbehaving. This may be something you're able to diagnose yourself (though likely requires digging deep up in the dash) or it may be possible for the dealer to diagnose which motor is faulty with the Jag software.
Old Feb 18, 2019 | 09:18 AM
lotusespritse's Avatar
A lot of Ford parts in that car, and Fords/Lincolns are infamous for having the blend door mechanisms break around 10 years old. Yours is in the worst possible place. It's a huge job to get into the dash to replace that one. Reminds me, I need to sell my XF's in a year or two before all of that starts falling apart.
Old Feb 18, 2019 | 10:05 AM
clubairth1's Avatar
Community Influencer
Well lets go with the more common problem??
Try changing your DCCV first. They are a known failure item and all will fail eventually.
Thankfully Jaguar removed this on the 5.0L V-8!
Old Feb 18, 2019 | 07:10 PM
He said he is not getting any air out of the center vents. The DCCV controls coolant flow, not airflow. I think he wants to solve his right now problem, not do a bunch of preventative maintenance for things that aren't broke.
Old Feb 19, 2019 | 12:52 PM
clubairth1's Avatar
Lets hope he posts back with the fix!
Old Sep 8, 2019 | 09:22 PM
swonkeXF's Avatar
Sorry for the late response, I lost my log in info so I've been MIA... i've since had the issue fixed with my local jag repair shop (not the dealership). as it turns out it was an issue with the AC solenoid which had gone out. all in it was a $500 problem. hopefully this helps with anyone who might run into the same issue!
Old Sep 11, 2019 | 11:45 AM
clubairth1's Avatar
So NOT the blend door!
Imagine that.
Old Sep 11, 2019 | 03:53 PM
Imagine that.
Don't get too excited just yet, clubby. I didn't see a part number for what failed. People confuse terms all the time, so who knows what they called a "solenoid."
digimurda
Feb 12, 2021 08:03 AM
JimC64
Jul 10, 2018 07:39 PM
Cameron96
Feb 3, 2018 03:52 PM
XxXxXxXxX
Feb 21, 2016 08:58 AM
