XF - Engine Light Issue
Old May 19, 2008 | 07:49 PM
jcapotos's Avatar
Default XF - Engine Light Issue
Anyone have issues with engine light? I have 1200 miles on my XF Prem Lux. It sat in the garage over the weekend and when I drove it today, the light was on from te point I started the engine. ANy known issues?
Old May 19, 2008 | 08:57 PM
ibjags's Avatar
Default RE: XF - Engine Light Issue
get it to the dealership
and let them diagnose
as far as known faults no
best advise would be to just get in into the dealer
Old May 19, 2008 | 10:46 PM
Randy's Avatar
make sure the gas cap is on tight (on one of my other cars, if the cap isnt all the way on, the check engine light comes on after about a day).. if it is, get it to the dealer like ibjags suggests..
Old May 21, 2008 | 07:41 PM
FactoryJaguarTech's Avatar
Seen 3 problems for check engine lights so far. All minor. 1. Misfire codes.....bad fuel. Not cars fault.
2. Secondary air injection code. No fix for it, software glitch. Cleared code and hasnt been back. 3. Evap emissions. Replaced DMTL pump. Side effect of this was also Check gas cap showing on cluster.
Take it to the dealer so you can get it looked at correctly.
Old May 21, 2008 | 08:20 PM
jcapotos's Avatar
JFT
The first thing i did was check the gas cap....no luck there. I have appointment with dealer tomorrow. willlet you know outcome.
thanks
Old May 27, 2008 | 05:39 PM
Any update? Did they clear codes and ship the car?
Old May 27, 2008 | 07:10 PM
jcapotos's Avatar
FJT
It turned out to be a bad sensor that had to be replaced. Up and running fine!
thanks
Old May 28, 2008 | 05:10 AM
nice. You know what code? What sensor? Should be on your copy of repair order. That info is always useful for us techs!!
Old May 28, 2008 | 05:59 AM
jcapotos's Avatar
Hi JFT
The details are:
Code P0492 - air injection valve (part#C2C32933). Hope thats helpful.
John
Old May 28, 2008 | 02:23 PM
Thanks. Can never have too much info.
Old May 28, 2008 | 07:18 PM
jag_genius's Avatar
propbably same one as 07 s.. there failing here left and right..
Old May 31, 2008 | 06:54 PM
Yeah, sai system is ****. Got word theengineers are trying to get a fix in the works. Likely software to just disabled altogether.
Entirely uneccessary system. Cats heat up fast enough without that.
Old Mar 23, 2014 | 07:54 AM
jaguarxfv8's Avatar
Default annoying
I have the same problem with the check engine light on but the car is running fine -__-
-clear the code, drive it for about a day and it came back on
-check evap
-check muffler
-check maf
what else ...
anyway thank for the tip !
Old Mar 23, 2014 | 08:25 AM
07XKJaguar's Avatar
Just for reference for the list. The CEL came on my 2014 with 500 miles on it. Dealer says it was the plug going to the coolant temp sensor.
Old Mar 25, 2014 | 11:30 AM
x358x250's Avatar
I just had the same issue with my 2009 premium luxury model with 58,000 miles. It drove ok but the engine light remained on. Checked gas cap - ok. The dealer replaced an O2 sensor, about a $400 repair. Runs fine and no dash light.
Old Mar 25, 2014 | 11:49 AM
jaguarxfv8's Avatar
The 02 sensor was my first guess but I called my dealer they said they never had to change an o2 sensors on a xf -_- Guess my dad was right.
Do you know wich one they change and the part number ? it should be on your bill !
X_Type_South_Africa
Dec 9, 2015 05:37 PM
Jimscriv
Nov 4, 2015 02:18 PM
big d
Sep 3, 2015 07:37 PM
Jandreu
Aug 29, 2015 07:31 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
