xf reversing camera
Old Jan 26, 2019 | 05:14 AM
Tomlark's Avatar
Default xf reversing camera
does 2013 xf jaguar 2.2d business have a fuse for reversing camera
Old Jan 26, 2019 | 06:36 AM
Cambo's Avatar
If your camera has stopped working then the most likely culprit is a break in the wiring harness that runs through the rubber bellows between the boot lid and the body of the car, it's a common enough fault. The harness bends each time you open & close the boot lid, eventually some wires break.
Old Jan 26, 2019 | 12:53 PM
Tomlark's Avatar
Default Tomlark
Thanks Cambo will have a look let you know
Old Jan 30, 2019 | 09:13 PM
nasa25's Avatar
Wiring harness develops a crack and lets water in which destroys the camera. Very common problem. Does the inside of your camera lens look cloudy or have massive condensation?
this happened to me. Camera had to be replaced.
Old Feb 7, 2019 | 01:53 PM
Tomlark's Avatar
Thanks guys for reply turns out camera wires broken in loom under rubber between boot and lid. Managed to solder wires camera working perfectly.
Paul Calvert
Sep 11, 2022 01:40 PM
Jose
Feb 5, 2019 03:47 PM
Tomlark
Jan 27, 2019 03:48 AM
VortexXL
Jan 20, 2019 04:25 PM
malbec
Jan 18, 2019 08:18 PM
