XFR Stalling / Starting when it feels like it.
Old Oct 5, 2016 | 08:17 PM
fastlanz's Avatar
Default XFR Stalling / Starting when it feels like it.
Hi Guys,
Having a strange issue with my XFR.
It's been running great however yesterday I drove the car for about 20 mins, shut it off, came back 10 mins later, got in, started it, put it in gear and drove about half a block. The car then just stalled and would no longer start. I got it to turn over a couple times but the car would not start.
Had it towed to the garage "here is how to put it in neutral you probably want to read this"
How To Tow A Jaguar Equipped With An Electronic Shift Lever
Went back to the garage this afternoon, disconnected the battery, reconnected and attempted to start again. Car turns over but won't start. Mechanic tries later in the day and the car starts up perfectly.
My feeling is the almost 6 year old battery is playing games or the fuel pump is on it's way out or something "else" is going on. There are no engine codes. Anyone else go through this?
Two weeks ago it stalled at a light but after putting it in park it started right up and was working fine for about 2 weeks until yesterday's adventure.
Thanks in advance...
Old Oct 5, 2016 | 08:59 PM
OzXFR's Avatar
"almost 6 year old battery" - there is your answer.
Plenty of threads around here on how the XF is very sensitive to battery condition, and how the OEM battery starts to deteriorate after around 4 years old.
Six years old is way past it's use by date.
Old Oct 6, 2016 | 06:49 AM
Blackcoog's Avatar
It's definitely the battery.
Old Oct 6, 2016 | 08:00 AM
2010 Kyanite XFR's Avatar
I wouldn't rule out the fuel pump. A friend had the same issues until his was replaced. Start with the battery and then move on from there.
Old Oct 11, 2016 | 08:03 PM
fastlanz's Avatar
Just thought I would provide an update in case this happens to someone else. The battery was changed. During the test drive the car stalled again but threw a code this time. Fuel pump is defective. Should have a new one installed in a couple days... Thanks again for the great feedback.
Old Jan 23, 2017 | 02:50 PM
Blueeyes3079's Avatar
Very helpful thank you! I have been trying to figure out the same issue on my car. Was the fuel pump covered under warranty?
Old Jan 30, 2017 | 11:00 PM
Cherry_560sel's Avatar
Great tip on the release lever. The X Type had a similar release under the gear shift trim that I had to use once. Was wondering if the XF also had this. Never know when it might come in handy.
Old Jan 31, 2017 | 03:30 PM
MarkN's Avatar
Kyanite nailed it!
Old Jan 31, 2017 | 04:31 PM
Originally Posted by MarkN
Kyanite nailed it!
Broken clock, blind squirrel....It was actually BiggWill that confirmed my diagnosis on my buddy's car so call it a team win
Old Feb 8, 2017 | 01:06 PM
Default Stalling fixed
Hey so I was having this issue on my car and it was the Fuel Pump harness. Dealer covered it under warranty. Car has been operating fine.
xtypejag502
Aug 27, 2016 09:18 AM
Peter Jones
Aug 24, 2016 08:12 PM
SinF
Aug 23, 2016 10:51 PM
XJ8dad
Aug 23, 2016 05:54 PM
