XFR temp gauge
Old Oct 8, 2020 | 04:02 PM
kansanbrit's Avatar
Default XFR temp gauge
Decided I would like to monitor coolant temp for peace of mind as I have just changed both head gaskets on this overheated engine.
Trying this Autotool X60 from Amazon, around $35. Just plugs in to the ODB port, comes with the cable. Easy peazy. You know what, I like it so far.
Old Oct 8, 2020 | 07:59 PM
Jssaab's Avatar
Good to have
I use PLX gauges can can show, coolant temp, boost, etc and I have the dash command app with a $10 obd dongle, work goos. I an thinking to make a pod for my old iPhone and mount that
Old Oct 8, 2020 | 08:19 PM
BritCars's Avatar
How does it measure temp? Is it a sensor in the coolant somewhere? If so, the issue is that if a pipe breaks and coolant escapes there is no fluid to measure temp and the engine can overheat
So it's helpful but not necessarily always.
Old Oct 9, 2020 | 06:14 AM
kansanbrit's Avatar
It gets temp value from ecu via odb.
Old Dec 20, 2020 | 11:20 AM
kansanbrit's Avatar
Makes a good digital speedometer too. Very useful as the speedo is so hard to see sometimes.
hdsg
Feb 28, 2020 02:02 AM
Gizze
Jun 28, 2017 10:00 AM
kr98664
Oct 26, 2015 05:36 PM
Bcrary3
Sep 3, 2015 03:48 PM
jvegas
Jan 17, 2009 06:59 AM
