XFS 3.0 liter diesel 2013 ABS fault
Old May 30, 2018 | 04:47 AM
ddd's Avatar
ddd
Default XFS 3.0 liter diesel 2013 ABS fault
Error codes
P2159 vehicle speed,
C0037 left rear wheel tone,
C1b00 brake pressure sensor.abs inop,traction control in0p cruise control inop dsc inop
Old May 30, 2018 | 05:47 AM
Welcome to the forum ddd,
I've moved your question from XK8/XKR to X250 forum. Members here with the same model will be able to help.
Old May 30, 2018 | 06:09 AM
Modern Jaguars use extended codes and it requires dealer level Jaguar SDD (Symptom Driven Diagnostics) or equivalent to read them.
For example, C0037 is a Left Rear Wheel Speed Sensor fault but the extended codes give more information:
(double click on the image to enlarge it)
The 12, 14, 25, 2F or 31 help to isolate a harness fault from a sensor failure.
Old Jul 12, 2019 | 07:22 AM
AWBW's Avatar
I have theC0037 and C1B00 on my XF-R, did you get them sorted? if so do you have any advice?
Mark Benton
May 28, 2018 04:06 PM
exiledbrit
May 17, 2018 10:32 PM
MediaBobNY
Apr 17, 2018 01:59 PM
lepae
Apr 8, 2018 05:30 PM
Pete Type X
Mar 17, 2018 04:13 PM
