XJ vs XF reliability
Old Feb 1, 2022 | 08:27 PM
Supercharged81's Avatar
Default XJ vs XF reliability
I am in the process of shopping for another vehicle. I am the previous owner of a 2010 XF Supercharged 5.0 . I am looking once again at the x250 XF models or possibly even x351 XJ models. I am thinking the XF overall will have better reliability than the XJ? Am I correct? Thank you.
Old Feb 2, 2022 | 02:27 PM
Jaaaggg's Avatar
Drivetrain wise, both are similar, as they use the same engine/transmission config. XF overall is slightly more reliable because it lacks some of the additional electrical components in the XJ. The earlier XJs have sunroof popping issues and the rear suspension has air springs, which are generally troublesome. The XJ is more advanced with its all aluminum chassis and overall exterior and interior design. Because of the all aluminum construction, the XJ is very similar/slightly lighter in weight compared to the XF.
Old Feb 2, 2022 | 02:41 PM
Thank you. I will stick w the XF models in that case, less to go wrong.
Feelergaugephil
Oct 2, 2021 12:16 AM
amcdonal86
Oct 23, 2014 04:27 PM
Wolfy
Exterior
Sep 17, 2013 04:09 PM
eunsulover
Apr 3, 2013 12:55 PM
mmorrismm
Jun 27, 2012 10:05 AM
