xjr xfr wheels are they interchangable
Old Sep 12, 2016 | 05:37 PM
mark campbell's Avatar
Default xjr xfr wheels are they interchangable
I would like to know if the 19 in. 04/05 xjr wheels will fit on a 2010 xf supercharged--don,t know the offset but xjrs are 19x9 thanks in advance
Old Sep 12, 2016 | 06:01 PM
OzXFR's Avatar
Probably not, the XF SC has the big 380 mm front brake calipers and all experience is that nothing less than 20" in Jag OEM wheels will fit over them.
Old Sep 12, 2016 | 08:12 PM
BritCars's Avatar
I don't think they fit. I believe that era used a 5x121mm bolt pattern. The more modern jags all use 5x108. So aside from the brake clearance issue with 19inch wheels, I don't think they will fit onto the bolts on the hub anyway
Old Sep 13, 2016 | 07:17 AM
the calipers!!!!!!!!!!!!!!I,ll have to check but the bolt pattern is the same I know offsets are different but was hoping they would fit .are the x350 /xjr brembo calipers smaller than those fitted to the xfr?---are all the spares the same size I have 1 spare from a 10 standard xf ----this is all temporary you see I purchaced a theft recovery 09 xfr.with no wheels need to do something to make it mobile---
Old Sep 13, 2016 | 05:29 PM
when you say brakes are 380 mm are you talking the assy. or just the rotor.was trying to figure out the size --I found the size of str/xjr eatly rotor 265mm---after 06 rotor went to 255 mm and from what I can tell the rotor size goes to 2010 xf also
Old Sep 13, 2016 | 06:20 PM
OzXFR's Avatar
The front brake rotors/discs are 380 mm in diameter, and the calipers are humongous.
Here's a pic I pinched from another forum:
Old Sep 22, 2016 | 09:07 AM
well they do work --got the car on Monday put 19x9 xjr wheels on it and it worke fine--thanks all for the advice
Old Sep 23, 2016 | 07:05 AM
IppoJ's Avatar
I do know that 19" Artura wheels *will* fit the XFR.
This isn't a guess, I fitted a set as winter wheels last night.
There was some debate about whether 18" wheels would fit the XFR and after seeing the 19s on, I can't imagine 18" wheels would fit.
Old Sep 23, 2016 | 07:06 AM
IppoJ's Avatar
Can you post up a photo when you have a chance? I'd like to see how they look.
Old Sep 25, 2016 | 06:38 AM
yes I,ll post pics --next week I hope
Steve W
Apr 7, 2021 10:45 AM
Steve W
Feb 2, 2018 05:10 AM
omgimali
Sep 15, 2016 05:26 PM
Playajw23
Sep 13, 2016 12:37 PM
jackra_1
Sep 12, 2016 12:45 PM
