ZF Transmission Service Locations??
Old Oct 19, 2019 | 03:04 PM
Roman85's Avatar
Default ZF Transmission Service Locations??
I’m trying to find certified ZF transmission locations in the Chicago land area and I’m having the hardest time... I’ll go to the dealer but I would prefer not to deal with those butchers.
2013 XFR 48k miles
Hearing a clunk/cling kind of noise when I let off the gas paddle, then when I press on the gas again another clunk/cling kind of noise. When I called the dealer the service guy said it’s probably my suspension... Highly doubtful in my opinion. Probably solenoids but I would like to have that confirmed and looked at by a REAL ZF certified professional.
The shifter also makes that same noise but louder when I shift from park to reverse or drive and the car jerks.
Old Oct 19, 2019 | 03:16 PM
davetibbs's Avatar
I'd be looking to swap out a) the rear transmission mount and b) the engine mounts before getting the transmission overhauled. It sounds much more like driveline shunt than a transmission fault. Check the guibo (flexdisc) out as well - it's not sold as a part separately by Jaguar but if you have a search @Bigg Will has done an excellent thread on replacing it with an alternative part.
Old Oct 20, 2019 | 02:54 PM
litteredwithfaults's Avatar
Also have engine mounts checked, its happening along with throttle inputs. Park it, watch the engine lump thrash more than it should while somebody gives it the boot, and listen for the clunk.
Old Oct 21, 2019 | 04:05 PM
Bigg Will's Avatar
Agreed driveline clunk is usually a driveline issue.
Old Oct 21, 2019 | 11:45 PM
Roman85's Avatar
Thanks guys!! This helps a lot!!
Old Oct 31, 2019 | 09:42 AM
Roman85's Avatar
Got some news back and I quote, “one of the transmission mounts is completely shredded.”
JLMedia
Apr 22, 2020 02:15 AM
jfintexas
Oct 23, 2013 05:16 AM
philhef
Apr 12, 2013 11:47 AM
mbates50
Dec 16, 2012 10:47 AM
