99 XJ8 trans fluid and filter change question
Old Aug 16, 2012 | 07:50 PM
kyxplorer's Avatar
Default 99 XJ8 trans fluid and filter change question
When changing trans filter and fluid in audi a6 i had to have the vehicle level on jack stands, running, once the cooling fans kicked on, then i would check the trans fluid level and add as needed. I could not find in the thread if the same procedure was needed for the XJ8. When verifing fluid level after change, is there a set procedure? I have a 99 XJ8 base model.
thanks for your input.
hunt
Old Aug 16, 2012 | 07:56 PM
plums's Avatar
There is a specific procedure and it is detailed in multiple threads.
Old Aug 16, 2012 | 08:08 PM
Take a look here https://www.jaguarforums.com/forum/x...-cd-faq-54942/
Old Aug 18, 2012 | 07:42 AM
jimlombardi's Avatar
Default Transmission ZF5HP24 Fuild & Filter R&I PDF files
Hello
Thank you Norri - The ZF5HP24 thread has the Fluid Drain & Refill procedure, but I noticed that I should have included the Filter removal & install PDF in that thread.
Here are 2 PDF files that cover ZF5HP24 Transmission Fluid & Filter replacement:
First one has instructions and illustrations on the Transmission Fluid Drain and Refill procedure:
https://www.jaguarforums.com/forum/a...l-44-24-02-pdf
Also you should look at these other 2 transmission fluid fill threads (since most of us do not have a PDU - Portable Diagnostic Unit - that the instructions in PDF file calls out):
https://www.jaguarforums.com/forum/x...ns-help-36256/
https://www.jaguarforums.com/forum/x...acement-61555/
The other one shows the Transmission Filter and instructions on its removal and installation:
XJ (X308) ZF5HP24 Transmission Filter R&I.pdf
Jim Lombardi
Last edited by jimlombardi; Aug 18, 2012 at 09:12 AM. Reason: Added weblink to a refill thread
Old Aug 19, 2012 | 07:28 PM
kyxplorer's Avatar
Thanks for all the info. I'm ready for the job. Its basically the same process that i used for my Land Rover and Audi.
thanks
hunt
Sprayall
May 30, 2021 08:13 AM
Sprayall
Sep 3, 2015 07:49 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
mrplow58
Aug 29, 2015 10:44 PM
dpappyp
Aug 27, 2015 06:31 AM
