Another aux input option - anyone tried?
Old Dec 3, 2011 | 09:02 AM
Anticitizen's Avatar
Default Another aux input option - anyone tried?
I've been looking over options to add an aux input to my car for mp3 use and came across this:
TranzIt USB IS32 - Universal Car Integration Kit for Smartphones, MP3 Players
Looks like the easiest solution - it uses the radio antenna lead on the back of the radio head unit to deliver audio. Looks simple and effective, but my only concern is that the audio quality might be radio-quality rather than CD quality... but I could be wrong. Anyone have any experience with this product?
Old Dec 5, 2011 | 09:22 AM
kthrash's Avatar
My Sirius radio is using an FM Modulator plugged into the antenna line.. Sounds great.. I cant imagine this being any different.
Old Dec 5, 2011 | 10:20 AM
SuperTrav's Avatar
Thank you very much for posting this. I will be ordering it mid-month.
Old Dec 5, 2011 | 11:04 AM
Thanks. I have ordered it, as well as a Blackberry bluetooth stereo gateway (compatible with any bluetooth audio device, not just Blackberries:
http://www.amazon.com/gp/product/B00...00_i01_details
I plan on getting the Kuda mount, too. My plan is to have all wires hidden. If everything goes according to plan, I should be able to drop my phone in the mount and play all music wirelessly via Bluetooth. I will post photos of everything with a report once I perform the installation.
Old Dec 5, 2011 | 12:21 PM
04XJ8's Avatar
Excellent. I'm looking forward to your review and feedback. This looks like a great idea. I'd especially like to hear your thoughts on the audio quality.
Old Dec 6, 2011 | 01:53 AM
mstolley's Avatar
Bluetooth devices I've used in the past sound awful - very degraded. I ended up reverting to plugging in. I'm an audio snob, so your results may vary.
Old Dec 6, 2011 | 06:33 AM
jake1's Avatar
I have hard-wired sirius with 3.5mm aux. cables in 2 vehicles...my 04 XJ8 and my 05 Ford F150. The sirus direct connect with the 3.5mm cables is a great way to add both sirius radio and Ipod/smartphone connection. The Jag input is through the antenna and the F150 is through an aux. port on the back of the radio. No comparison. The F150 is CD quality and the Jag sounds like radio.
Weren't many options when looking for a connection to the Jag Alpine unit, so the antenna route was acceptable, but sound quakity is certainly compromised. The Jag Audio Connectivity Module seems like the best way to go, but I didn't know it was available when I had mine installed.
Old Dec 6, 2011 | 09:45 AM
I can live with radio quality, so long as it's not mono and staticky. The ACM is too pricey when all I need it for is the 3.5mm jack.
Old Dec 6, 2011 | 10:48 AM
BadinJezebel's Avatar
Thanks Anticitizen for the link. Please let us know how the installation went. I'm looking to do the same thing.
-James
Old Dec 6, 2011 | 11:53 AM
gbs28173's Avatar
Me too- really want to see how this works out.
Old Dec 7, 2011 | 01:41 PM
Anyone have a link to a good photo or video guide to the disassembly of the stereo and trim?
Old Jul 3, 2012 | 01:48 PM
gbs28173's Avatar
Default Well I did it- Aux input installed.
Installed this kit from ISimple which just has the Iphone/Ipod cord (which is what I was after): iSimple TranzIt IS77 - Universal Car Kit - iPod, iPhone, iPad, Audio Devices ($48 delivered on ebay)
1. Remove rear center console vent assy (no screws-just pry out carefully with a plastic or rubber pry tool) and then disconnect the electrical connectors for htd seats and lighter (mine has no rear audio or ACC) and remove the 2 torx bolts behind it to unattach from console. I also removed the storage tray under the armrest which wasn't necessary.
2. Remove the black plastic trim piece and then wood trim around shifter. There are no screws here just clips and it pulls straight up. I was afraid of cracking the wood but turns out it is backed with metal.
3. Remove 2 torx screws holding the side trim pieces to the console and then remove the 2 ashtray retaining screws (under small round covers).
4. Pull ENTIRE center console assembly (from the top piece that ends over the heated seat/hazard switches) all the way to the rear vent that you removed earlier STRAIGHT BACK. Then remove ashtray assy.
5. Remove the 2 screws that hold the metal bracket that holds the audio and climate control units and pull forward to gain access. Connect the unit per directions. ***You will need 2 antenna adapters (a 40-EU20 and a 40-EU10) that I got at the local car audio place for $15 each***. There is plenty of room above the audio unit and behind the CC unit for the Isimple unit and wires. Set the gain on the unit to max (which is how it comes from the factory)
6. I ran the Ipod/Iphone cord through a groove I cut above the lighter in the plastic and mounted the power switch right in front of the lighter next to the ashtray itself. I used a Scotchlok to tap into the lighter power wire (white one I think) which was very convenient and is switched with the ignition.
7. Sound quality is better than expected and I can listen to my Ipod playlists, podcasts, or Pandora. I haven't used the CD or factory AM/FM since I installed it. I set my radio frequency to 87.9 and I occasionally get static if I drive through an area with an close frequency broadcasting. As an added bonus the phone charges as I use it.
Hope this helps someone who is considering a similar install...
Old Jan 2, 2013 | 09:14 AM
I finally got around to doing this myself. The setup is sweet, but the audio quality stinks - there's a hiss in the background, some static at volume, and I can hear a whine that increases as I accelerate. I'm going to take it all apart again this weekend and try to separate the power lines from the audio cables and antenna leads - I had everything bundled together, tied for neatness... I think it's creating some interference.
Old Jan 2, 2013 | 09:54 AM
reyesl's Avatar
One might experiment with this: Jaguar Antenna Adapter FM Modulator Wire Set 2000 2008 | eBay
It is cost effective.
You may do one or all of the following to eliminate noise:
Add shielding to the adapter cables
Install an Ignition Noise Filter
Install a suppressor
Check the antenna ground
Add grounding to the adapter cables
Check all media grounds
Old Jan 2, 2013 | 11:47 AM
brakeboost's Avatar
Great, look forward to seeing your installation.
Old Jan 2, 2013 | 07:12 PM
Thanks for the advice... I will check all those things out.
So, here's some pictures and video! Sorry for the quality (and my rambling nature). I had to use my ancient cell phone to film this because my other phone was being used in the demo.
The whole setup consists of:
1) A Kuda mount, fitted with neodymium magnets scavenged from an old hard drive to allow me to magnetically stick my phone to the Kuda without any mounting brackets or whatnot - in conjunction with the magnetic Powermat case I use on my phone
2) iSimple FM modulator kit with antenna adapters
3) Blackberry stereo gateway connected to the modulator, hidden inside the Kuda mount, wirelessly connected to the phone
I found the easiest place to tap for power was off the rear cigarette lighter. Installation was a lot easier than I expected. I've had most of the parts to do this for over a year, but I was afraid I'd ruin something when trying to take the center console out. It's actually dead simple (thanks to gbs28173's simple instructions above).
The poorly lit video!
https://www.youtube.com/watch?v=55nYGjptUM4
The crappy photos!
Mount in action
Very strong neodymium magnet holds the phone in its place.
Mid-installation.
The Blackberry bluetooth stereo gateway, hidden in the Kuda mount.
The button that turns the FM modulator on and off.
Attached Thumbnails Another aux input option - anyone tried?-rrnd4.jpg   Another aux input option - anyone tried?-uh94q.jpg   Another aux input option - anyone tried?-4yurn.jpg   Another aux input option - anyone tried?-asduk.jpg   Another aux input option - anyone tried?-zrn8n.jpg
Old Jan 2, 2013 | 07:27 PM
reyesl's Avatar
Your photos might have given me an idea on how to tap into the video cables. I have to replace my J-gate, so I might experiment with the video tie-in at the same time.
Old Jan 2, 2013 | 07:32 PM
Color me interested...
Old May 17, 2013 | 04:06 PM
Xj220twr's Avatar
Default Fm modulator Sat Nav model
Hello i installed one the jag xj8
Fallow the instruction to remove the center counsel.
2 remove radio need to put car in D to pull out.
remove Antenna input install adaptors shown in picture to RCA jack in and out route the wires i chose the right side method under the ash tray then side by plastic ac conduct to center counsel shown in the photos took 2 hrs. Also i took 12+ from cigarate lighter in the back the right one and grounded the - on one of the bolts that hold the gear selector it came a fuse link so did not mind the out put to jock is placed in the center counsel as seen in the photos. Hope this helps some one. Also did not come with but i put 2 tex T for added strength messure before u cut or drill that u have enough of a space between a the arm rest and the plug out put so it can close.
Attached Thumbnails Another aux input option - anyone tried?-imag0779.jpg   Another aux input option - anyone tried?-imag0776.jpg   Another aux input option - anyone tried?-imag0780.jpg   Another aux input option - anyone tried?-imag0774.jpg   Another aux input option - anyone tried?-imag0781.jpg
Old May 29, 2013 | 10:14 AM
GvilleVDP's Avatar
So how did all this end up for you? I bought my car with the sirus radio already wired in like this and the sound quality is not great at all. Is this our only option to get an AUX cable in? I have the nav system, if I fitted the phone part with it, could I BT audio as well?
rominempire
28
Oct 8, 2020 10:39 AM
Presence
Mar 13, 2016 02:21 PM
37driver
Oct 1, 2015 03:02 PM
pnwrs2000
Sep 30, 2015 01:56 PM
