XJ ( X351 ) 2009 - 2019
2011 Jaguar xjl Needs to be timed
Old Oct 31, 2014 | 09:33 PM
kain3488's Avatar
Default 2011 Jaguar xjl Needs to be timed
Engine skipped timing and need help how to, time engine, jaguar manual not helping.
Old Nov 5, 2014 | 05:15 PM
Fraser Mitchell's Avatar
Do you mean the valve timing ? You haven't said what engine it is.
Only the diesel engine has a timing belt that could "skip", due to serious wear. If it is this, then much more than just retiming is needed, you need to check for valve damage. As a minimum a new cambelt is needed. It is the same engine as the Peugot V6 2.7 litre diesel so look there if you can't find any Jaguar instructions.
Old Nov 5, 2014 | 06:41 PM
Welcome to the forum kain3488,
I've moved your question from General Tech Help to X351 forum. Members here with the same model will be able to help - if you give some further details!
Johncy2000
Aug 5, 2019 07:20 PM
Johncy2000
Dec 15, 2015 08:02 PM
ronald4313jm
Sep 27, 2015 03:48 PM
ronald4313jm
Sep 7, 2015 01:16 PM
Johncy2000
Aug 27, 2015 12:23 PM
