XJ ( X351 ) 2009 - 2019
2011 XJ 3 months old Nothing But Problems!
Old Aug 3, 2011 | 01:02 AM
otter1's Avatar
Default 2011 XJ 3 months old Nothing But Problems!
Here we go
1) Roof popping
2)Sunroof stop working
3) Squaking noise above drivers head
4) Tire sensor not working
5) side mirrors stuck in close position
6) Car won't start had to be towed
7) door locks not working
8) Battery dead
9) radio stop working
10) air conditioning not working
11) Car overheating had to be towed again
12) all this in 3 months any attorneys reading this
13) Jaguar needs to fire all vendors and workers who put this piece of crap together period.
Old Aug 3, 2011 | 01:08 AM
direng's Avatar
Did you check for issues on the Forum before you bought it?
I have read most of the issues listed on various threads.
Old Aug 3, 2011 | 03:09 AM
Cadillac's Avatar
Sorry to hear about your glitches , some problems you mentioned should be related to battery as well . Roof popping is the most common issue from what I see
Old Aug 3, 2011 | 06:07 PM
HouTexJag's Avatar
Sorry to hear about all those problems otter1--sounds like a major electrical issue. There certainly seems to be a broad range of experiences with this car. The only problem I have had in 12,000 miles and 13 months of ownership with a very early VIN car is the roof popping that was fixed permanently in the first couple of months. No overheating or A/C problems even in the horrible heat wave of 100+ degree days we are having here in Houston (they did add some freon when I took it in for the 10,000 mile service, but it was still cooling okay).
Old Aug 3, 2011 | 06:15 PM
Jffcurt's Avatar
Wow! You look like you've had every problem none! I did have the air conditioner/overheating and that was due to the engine cooling fan going out. They replaced it and it's fine for now. I will say also that last night while driving the Tire Sensor Default warning came on (big yellow triangle) and I had never seen that before but it "fixed" itself and hasn't come on since.........
Old Aug 4, 2011 | 06:44 PM
HouTexJag's Avatar
I know my tire pressure monitoring system is working fine because I have a small nail in my left rear tire causing a slow leak and about every 2 weeks I get a warning about that tire--as soon as I add air the warning goes away.
I did get the tire pressure monitoring system fault warning once too, but it reset after I turned off the car and let it sit overnight. It was really hot that day and I wonder if that affected the system. I see you're in Orlando, so that might be your problem as well.
Old Aug 4, 2011 | 07:33 PM
kid delicious's Avatar
Sorry to hear about your issues Otter. On a positive note, it looks like you're taking care of the majority of the glitches quickly, so it should be smooth sailing going forward. When I bought my M5 years ago, the first three months it was in the shop. Electrical glitches out the wahzoo. After that...not a thing went wrong for the next three years until I sold it. And the guy I sold it to has had it for three years since, and he hasn't had a problem either. Just thought I'd spread some positive energy your way.
Wolfy
May 28, 2024 08:06 AM
JarodL
Mar 7, 2024 01:39 AM
jgatto
Sep 21, 2015 11:24 PM
Skeeter
Sep 17, 2015 08:15 PM
mcdutch
Sep 4, 2015 03:38 AM
