XJ ( X351 ) 2009 - 2019
2011 XJ 5.0 Manfacture???
Old Oct 15, 2020 | 03:04 PM
mfosterjdc's Avatar
Default 2011 XJ 5.0 Manfacture???
Recently went to a repair shop and was told there were several different manufacturers of the engine that went in my year XJ 351 they tell me it an bmw engine??? I thought they were Ford engines....
Old Oct 15, 2020 | 03:07 PM
XJ8JR's Avatar
Wrong on all counts. The 5.0 engine was and is manufactured by Jaguar. However, I think they were (maybe still are) built in a corner of a Ford factory that Jaguar rented out, or something like that. I think you need to find a new repair shop.
Old Oct 15, 2020 | 03:34 PM
clubairth1's Avatar
Community Influencer
Yes they are very wrong!
Find a different shop with at least some knowledge of Jaguars.
Old Oct 15, 2020 | 03:50 PM
Fraser Mitchell's Avatar
The engines were made by Ford in their factory in Bridgend, Wales. Ford are closing this factory and Jaguar have purchased the production machinery for the V8 and moved it to their factory in Wolverhampton where production will carry on. The V8 is still a market requirement in many countries, especially the USA. However, how much longer it will remain in production is an open question.
Old Oct 15, 2020 | 04:13 PM
mfosterjdc's Avatar
Thanks for the support and the replies..I thought she was wrong about it..What about the transmission is that a Ford produced as well? They were trying to tell me it was going to e $800-1000 for trans service.... Looks like I'm going to have to go to Charlotte to get any thing major done
Old Oct 15, 2020 | 04:24 PM
Thermo's Avatar
Veteran: Navy
mfosterjdc, to say that ford made the engine is a bit wrong. Are there a significant number of parts that are Ford. Yes, just look under the hood at all the ford ovals. Where the difference comes is jaguar would get their "pick of the litter" and get to pick the parts that they wanted. They would then put the parts through additional measurements and whatnot to match up parts to make the engines perform a little better and be more balanced (for example, they would weigh the pistons and find a set of 8 that were very close in weight to each other vice allowing a bigger tolerance). The engine block is different. So, it is defnitely not 100% Ford. But, there is a significant fraction that is.
As for the tranny, that is not a Ford product at all. That is a "generic" transmission made by a company called ZF. ZF makes transmissions for most car companies. So, I guess you could call it a Ford tranny, but it is as much a chevy, Mazda, or Nissan tranny in that regards. The 6HP26/28 (what is in your car) is also used in BMW's and other higher end cars because of the power capabilities that the tranny has. As for the cost of the service, they are a bit high, but not that much. You are going to get hit for 3 hours of service. So, that is going to be $300-400 right there (most shops are charging around $100 an hour for service). Then you start looking at where you buy the parts from, I can see where you could easily get the price up to $800. I bought my own parts and then had a shop drop the pan and fill the system and do an internal inspection and that ran me like $250 for the work and around $225 for the oil and pan. Now, I did buy a few extra bottles just to make sure I had enough fluid. So, that added to the cost. But, I was still nearing $500 for the tranny service and trying to save money in the process.
Old Oct 15, 2020 | 04:29 PM
mfosterjdc's Avatar
Thanks Thermo I think that clears it up for me....
Old Oct 19, 2020 | 07:33 AM
Woosy's Avatar
Default Aj8 5.0 litre
https://www.jaguarheritage.com/jagua...g/ajv8-engine/
follow the link and it will explain the origins of the AJ8.
Old Oct 22, 2020 | 07:19 PM
Donm's Avatar
Always wondered if the Mustang 5.0 hot engine was same as the super sport plant.
Old Oct 23, 2020 | 01:31 PM
clubairth1's Avatar
Thanks much Woosy!
That has the full story of the engine.
robertpel9
Jan 25, 2020 07:33 PM
Pa.Bill
Dec 22, 2013 07:32 AM
AutoMedia
Dec 15, 2010 03:06 PM
RET
Nov 27, 2010 04:06 PM
hunterjah
Sep 14, 2010 05:24 AM
