XJ ( X351 ) 2009 - 2019
2012 vs 2015 XJL help in choosing
Old Jan 18, 2019 | 02:48 PM
Paul2005's Avatar
Default 2012 vs 2015 XJL help in choosing
Hi all,
I am considering buying used XJ L and am looking at either a 2012 with the 5.0 L V8(probably NA) or a 2015 with the 3.0L supercharged engine with AWD. Obviously the 2015 is more expensive, however, I am interested in finding out what issues people have had with both model years to help me choose if the 2012 is still a good choice. I have been reading many of the threads here and also other reviews of both years and am not sure which would be best, the idea of more HP and rear wheel drive appeals although I live in Ontario Canada so the AWD system would be useful in winter. Any input or comments would be appreciated. Thanks for your time.
Cheers Paul
Old Jan 18, 2019 | 03:11 PM
Thermo's Avatar
Veteran: Navy
Paul, I have a 2012 XJ with the 5.0L NA motor. In the 4 years that I have owned the car (60K miles driven), I have only had to replace tires, front and rear brake pads, and a new water pump. If there is a weakness in the 2012, it will be the water pump. You may also find that the 2012 will have a bit more sunroof noises (popping sound). It has supposedly been fixed by the 2015 model.
Both cars are going to be fun to drive. I think the questions you need to ask yourself are as follows:
-Is one in the color that I want (interior and exterior)?
-Does the AWD for adverse weather override a lot of other wants/needs?
-When driving the car, do you like to go fast in a straight line or do you like to push the car through the corners?
The color question is pretty obvious. As for the AWD, this one is pretty obvious. As for whether you like to go in a straight line or through corners, this is where the RWD and AWD are going to differ. The 2012 RWD car is going to get up and go better. Where the 2015 AWD is going to grip in the corners better and allow you to really toss the car around. The 2012 RWD is not going to be a slouch, but you will be able to go a little deeper and harder into a corner with the 2015 AWD.
Old Jan 18, 2019 | 03:27 PM
MV Rider's Avatar
I have a 2015 XJL 3.0 AWD and have had zero problems with it. I bought in July 2017 with 7995 miles and it now has a little over 25,000 miles on it. It is my only vehicle and sees both in town and trips. You can always pay for more power but here in North Carolina I don't know what you would do with it around these cell phone using, left lane sitters that we have. I routinely ride 750 and larger motorcycle on the track so I appreciate having power to spare but on American highways it is becoming harder and more dangerous to use it, not to mention the revenue collecting law enforcement. I would go with the 2015 provided it meets your budget and is the right color and equipment for you. I don't think you will be disappointed with the 3.0 and yes I have driven the 5.0 SC(470HP) and it is faster but what are you going to do with it other than get tickets and spend more on gas.
Old Jan 20, 2019 | 07:35 AM
Stuart S's Avatar
I'm in Georgia and love the 5.0LSC engine in my 2013 XJ. But if I lived in Ontario, like the OP, winter driving conditions would make AWD essential. Since AWD is not available with the 5.0L engine, I have no choice but to get the 3.0LSC engine if I want an XJ.
Old Jan 21, 2019 | 07:20 AM
Gpfarrell's Avatar
200 pounds of ballast over the rear axle makes an impressive difference in mobility.
I’d favor the 5.0... especially the Supercharged version... over the 4-bad-days-a-year you’d really need AWD.
Old Jan 21, 2019 | 09:08 AM
christ's Avatar
So that's what wives are for!
Old May 31, 2019 | 07:58 AM
Paul2005's Avatar
Thanks for all of the input. I decided to go with newer and the 3.0SC. Picked up my 2016 XJL yesterday. Will post some pics shortly. Really looking forward to this weekend when I will have time to let the big cat run. Cheers!
Jesse James
Feb 21, 2019 04:45 PM
socialjaguarfan
Jan 26, 2018 11:44 AM
jayd
General Tech Help
Jul 5, 2012 05:04 AM
xjr350
Jun 21, 2011 06:31 PM
jimatvs
Apr 5, 2011 07:50 PM
