XJ ( X351 ) 2009 - 2019
2012 xj 5.0l sc ,plastic timing chain guild tq spec
Old Mar 25, 2021 | 12:32 AM
Rick Right's Avatar
Default 2012 xj 5.0l sc ,plastic timing chain guild tq spec
2012 xj 5.0l sc timing chain plastic guild bolts torque spec , believe this is the part number for the bolt c2p14810 m6x1.0 jag here doesn't have a clue tried for 12 foot pounds and it snapped so assuming its much lower 1,c2p148cp14810 10,
Old Mar 25, 2021 | 06:30 AM
Welcome to the forums Rick Right,
Please use capital letters and the occasional full stop where appropriate. A string of text is tedious to read and many members simply will not bother.
Here is the engine torque list from the Workshop Manual:
Without checking the Parts Catalogue, I think you are refering to the fixed guide retaining bolt. If so, the problem is likely to be confusing the specified torque number in Nm for lb-ft. The required 12 Nm for the fixed guide retaining bolt is equivalent to 9 lb-ft. Torqued to 12 lb-ft represents over tightening by 33%.
craneman1
Sep 11, 2025 05:58 PM
Gabriel Kat
Jun 28, 2020 01:56 AM
itrustno1
Mar 28, 2020 12:40 PM
jlfloerke
May 30, 2015 10:48 AM
reedster
Dec 2, 2012 08:37 AM
