XJ ( X351 ) 2009 - 2019
2012 XJL water pump replace?
Old May 22, 2022 | 04:19 PM
leaddog11's Avatar
Originally Posted by Thermo
Harrosito, the list is pretty short and I can't seem to find a good picture to show you what I am referencing. But, if you get near the water pump, you will be able to pick out these parts with ease. The parts of concern are:
1) the small (6mm?) plastic line running from the overflow bottle to the piping near the water pump. This is out in the open, not supported, and easily bumped/broken. This is a TRUST ME!!!!!!!!!
2) On the back side of the water pump, there is a roughly 3 inch/80mm piece that connects the water pump to the oil cooler. There is a metal version of this out there, get it if you can.
3) the elbow going into the water pump at the 4 o'clock position (when standing in front of the car). This piece has been redesigned a number of times to change how the seal removes any water pressure pushing against the bearing, leading to an early failure of the bearing.
4) the small tube coming off the front of the water pump, up to near the intake, running over to the right side. It has a funny Y shaped plastic piece in it that serves no purpose (did back on the original design, but not any more).
great info. Thanks
Old May 23, 2022 | 11:33 AM
leaddog11's Avatar
Would anyone have the part numbers for these parts
Old May 23, 2022 | 11:35 AM
leaddog11's Avatar
Would anyone have the part numbers for these parts?
Old May 23, 2022 | 12:21 PM
Sabrinaservicewriter's Avatar
Hey Leaddog11! I recently posted the complete list of parts we replace when working on the coolant leaks for these jaguars. Here is what I posted, hope this helps!
Part number AJ811713 which happens to be the same as the Land Rover gaskets part number LR010881-it takes 8 to do this job.
Also I have done a lot of research and have a great relationship with my local Jaguar dealership parts department and can provide you with the land rover part numbers for some of the other parts needed for this job. Hope this helps!
  1. AJ813565 -LR092992
  2. C2Z28467 -LR049989
  3. AJ89664 -LR018275
  4. AJ813909 -LR097165
  5. C2Zl8658 -LR028136
  6. AJ811539 - LR030593
  7. AJ814007- LR109402 this part number can also be found as C2Z31645 it was the original part number
If you type these numbers in on google it will provide you pictures of the parts, if you need any more help I'd be happy to help if I can!
Old May 23, 2022 | 01:09 PM
atraudes's Avatar
I appreciate that list a lot!
Interesting to note: all of the parts you listed are available on FCP Euro (lifetime warranty!). Their catalog is a bit weak in the Jaguar realm though, so most parts can only be found by the LR part number. Also interesting to note: the Jaguar water pump is $420 and the LR is $240 so it pays to do some extra looking.
For posterity, for 5.0 SC engines folks will need intake gaskets LR011585, LR011586, and LR011343. The AJ81171/LR010881 is applicable for 5.0 NA. I don't think some of the cooling system parts are applicable to SC models either, so if you're in that boat double-check to make sure it fits before ordering. I figured it was worth mentioning since OP has a SC model.
Old May 24, 2022 | 06:15 PM
leaddog11's Avatar
Originally Posted by rothwell
My 2011XJL 5.0NA still has the original cooling system parts. Only about 22K on the car now. So this work is in my long term plans. No existing issues...yet.
Recently I went to my local dealer to get a parts list of cooling system stuff I should replace. I attached a PDF of the list along with exploded views to reference.
Parts listed are below. Wondering if this list is complete enough? Anything missing I should include?
  1. AJ813565 HOSE
  2. C2Z28467 TUBE
  3. IAJ89664 PIPE-OUTLl
  4. AJ813909 PUMP-WATEI
  5. C2Zl8658 TUBE
  6. AJ811539 SEAL
  7. lc2D6005 HOSE-ENGH
  8. AJ814007 PIPE-HEATE
great info. Thanks
Old May 24, 2022 | 06:18 PM
leaddog11's Avatar
Originally Posted by Sabrinaservicewriter
Hey Rothwell!
Your dealer has included the right parts for the water pump! In our experience, replacing the intake manifold gaskets because of the age of the vehicle would be a good idea. Part number AJ811713 which happens to be the same as the Land Rover gaskets part number LR010881-it takes 8 to do this job.
very helpful. Thanks
Old Jun 5, 2022 | 06:41 AM
  #28
leaddog11's Avatar
HIstorical, welcome to The Forums. I think you are going to find this to be the place that you are looking for. We pride ourselves on being a better car group. But, as part of this, we like to get to know one another. So, please stop by the New Member section and tell us a little bit about yourself and what brought you to your jaguar. This will also give you a chance to meet those that make this place what it is.
As for your question, I would say to first come over to the X351 section (for all XJs 2009-2019). Here you will get all the info you need about your car and lots of helpful information. As for the water pump, I would not worry so much about the water pump, but more with the plastics that are around it. The plastic seems to be what is failing more times than not. There has been a lot of discussion on this very topic in the X351 section and you will find that the water pump complex has been redesigned a number of times. With this being said, is replacing the water pump a good bit of insurance, it sure is. Especially when you figure that a new engine for your car can run up to $45k (ask some of the members about the quotes they got from their dealership after they drove their car hot).
The big things that you want to pay attention to is the small tubing in the near right side of the engine bay (as you are standing in front of the car, looking into the engine bay). This tubing gets brittle with heat cycles and will suddenly crack (especially when working in the area). and there is a plastic transfer tube on the back of the water pump that feeds the engine that will suddenly split, resulting in major water loss. This transfer tube, someone has actually come out and made a metal version of it (info in the X351 section). So, if you do the water pump, spend the little bit extra and get that. Unfortuatnely, for what you are looking to do, you can probably plan on spending about $1500 on the water pump. BUt, like I said, it is good insurance from a major inconvenience.
thanks
Old May 2, 2023 | 05:31 AM
QP7's Avatar
QP7
Very helpful information - much appreciated; thank you.
dtrain
May 22, 2022 04:26 PM
JordanXJL
Sep 7, 2021 07:29 AM
murphman
Nov 26, 2018 08:24 AM
JamesTX
May 22, 2018 07:23 AM
