XJ ( X351 ) 2009 - 2019
2015 Jaguar XJR Transmission Jerk
Old Jun 26, 2021 | 09:34 AM
Tomwhite's Avatar
Default 2015 Jaguar XJR Transmission Jerk
Has any body experienced this before?
1. Drive the car for 10-15 minutes or more
2. Stop the car while the engine still running then select park
3. apply the parking brake
3. leave the engine running for 1 minute or so
4. apply brake pedal
5. put the car on drive while still applying the brake pedal
6. wait 2-3 seconds (while still applying the brake pedal) and the transmission selected on drive
7. release the brake pedal (not slowly)
8. the car will jerk you can feel strong jerk on the car.
I went to the dealer they reset the adaptation but this didn't make any difference, then they suggested that I need a new transmission, I am quite reluctant to replace the transmission, I would appreciated if any one of you who has the 8 speed ZF Gearbox experienced this before and if it is normal.
Thank you in advance
Old Jun 26, 2021 | 01:25 PM
ChaosphereIX's Avatar
did you release the parking brake?
Your car seems to be running fine. It is a very strong engine and a very tough transmission, we see very, very few failures or issues with the zf 8 speed. My car will seem to want to move even with brake applied sometimes.
Old Jun 26, 2021 | 04:42 PM
Tomwhite's Avatar
Hi, Thank you for your reply, forgot to mention with the procedure that I mentioned the eco start/stop feature needs to be turned off, the symptoms after doing the procedure that I mentioned, after selecting drive in step No. 5 the car does not feel it has engaged drive until after step No. 7 I feel a very strong kick of engagement to drive thats why I called it "jerk"
Old Jun 27, 2021 | 07:57 PM
AlexJag's Avatar
Sponsor
Same here. Some jerkiness to this transmission noticed . Maybe adaptation procedure needs to be complete. I know on my old ZF in my 08 Xkr had same issue until did adaptation but not sure whats the procedure on this new 8spd
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
2018 Jaguar F-Type (AlphaJag ECU TCU, lower upper pulleys intake) 10.77 ,131mph ,700hp
Old Aug 15, 2021 | 06:50 AM
Tomwhite's Avatar
Just an update about the issue with the gearbox with many thanks to ChaosphereIX and AlexJag for their inputs, the car went to the dealer, after diagnosing the issue they reset the adaptation three times on three separate occasions but this didn't solve the problem, then they recommended to replace the Gearbox, so now the car have a brand new (Not Remanufactured) Gearbox and Torque Converter installed and no more of this problem again.
Old Aug 15, 2021 | 09:32 AM
I am genuinely surprised, the ZF8 is a very strong unit as long as it is maintained.
Old Aug 15, 2021 | 04:19 PM
clubairth1's Avatar
Community Influencer
Glad to hear it's fixed but agree it's a rare failure. Lucky my 2014 XJR is still smooth as silk.
sogood
Apr 28, 2021 03:56 AM
Tomwhite
Mar 15, 2021 07:24 AM
pragmatic
Jan 2, 2019 09:07 AM
coldpad1
Jul 8, 2015 02:02 PM
