XJ ( X351 ) 2009 - 2019
2015 XJL passenger rear window
Old Oct 30, 2024 | 10:11 PM
bknorwood's Avatar
Default 2015 XJL passenger rear window
Well, I purchased this car a few months ago, and now it’s time to start addressing the few minor faults I’ve found - mainly just a few trim/interior parts that need to be replaced.
The one item that has broken *since* the purchase is the subj window/shade. Totally inoperative from either the master (driver) panel or the door switch.
Is the most likely culprit a bad door switch, or would it be the driver’s master panel switch? Is there a troubleshooting procedure someone can lay out for me? This is my first modern Jag (I have a ‘91 XJS Coupe), and I do all of my own maintenance whenever possible, so lay it on me.
Thanks in advance!!
Brad
Old Oct 31, 2024 | 06:50 AM
IanXF's Avatar
I had to replace the module on the door make sure the numbers match because one if for the door shade and one is not
wrd0225
Mar 19, 2022 09:03 AM
wrd0225
Mar 17, 2022 09:20 PM
ChristianC
Dec 31, 2019 10:20 AM
mark campbell
Oct 22, 2013 06:53 AM
peel
Aug 20, 2013 12:45 PM
