XJ ( X351 ) 2009 - 2019
2016 XJL Headlight Retrofit?
Old Aug 19, 2016 | 08:45 PM
  #61
howhwee's Avatar
Thanks!!! I thought it's simply removing a few nuts to pop the headlight. I bought the attached LED to fit into the Headlights but now it seems "mission impossible" ....
Old Aug 26, 2016 | 12:40 PM
  #62
Majidesam's Avatar
Default XJL 2015 front lamp connection
Hi , i have XJL 2014 and would like to change the head lamps to 2016 do you have pictures for the connector after shifting the cabeles? If no, can you take and send them to us .I have the new lamps arrived and waiting for the connection only. Regards, Essam
Waiting for your reply
[/QUOTE]
Old Aug 26, 2016 | 09:30 PM
  #63
howhwee's Avatar
Default Headlights replacement
Hi, sorry I am not able to help as I didn't manage to add these LED to my Headlights. I seen a thread in this forum that someone else manage to replace their headlights but you have to modify these 2016 lights in order to fit them to your XJL. Let me know if you manage to get them replace.
Old Aug 26, 2016 | 09:38 PM
  #64
Stuart S's Avatar
See: https://www.jaguarforums.com/forum/x...nality-167689/
Old Aug 27, 2016 | 04:54 AM
  #65
xdave's Avatar
To add to to the two replies above - you only need to modify the headlamps if you want to retain the static cornering lamps. If you do not mind losing those, or don't have them anyway, then you can do it entirely car-side by modifying the wiring behind the headlamps. Stuart's link explains both processes.
Old Sep 3, 2016 | 12:01 PM
  #66
Serlock's Avatar
i wonder if its possible to make UK spec to LHD ? Cause i see there are more headlights for sale in UK and they are cheaper there.
Old Sep 3, 2016 | 02:37 PM
  #67
xdave's Avatar
They are not compatible. The projector lens beam pattern will be wrong for LHD (it kicks up to the left, which will blind oncoming drivers). When I had mine apart I did not disassembly the projectors themselves so I am unsure how the beam pattern is fixed. I couldn't say for sure you would be able to adapt them.
Although not an issue for you in Lithuania, it is worth mentioning that US markets require amber side markers too, which are not present on the UK units.
Old Nov 1, 2016 | 12:09 PM
  #68
K39's Avatar
K39
Hi guys, does anybody know how the Rostman's installation has happened?
Thank you in advance..
Old Sep 25, 2017 | 12:41 AM
  #69
Mohamed Ossama Hamdy's Avatar
Hi. I have XJL 2014, i want to install the new LED headlights. I'm leaving in Dubai. Anyone knows from where i can buy it? And how much it costs?
Old Nov 18, 2017 | 01:00 PM
  #70
David Boole's Avatar
Originally Posted by Rostman
New LED headlamps retrofitted successfully. Everything works fine.
Hi I am about to do the same conversion have they been ok since fitted
Old Sep 10, 2018 | 04:44 AM
  #71
Darealwoody's Avatar
So i've get the new LED hedlights. Hope to get it on soon.
did you have to cut any wires? Or was it just a plug and play installation? I’m thinking about going to a dealership to purchase but I don’t know if just by plugging lights into my hornace if it would fit
Old Sep 10, 2018 | 04:46 AM
  #72
well I’m sure they fit, I don’t know if they’ll work by plugging my hornace into the new versions
Old Sep 10, 2018 | 04:53 AM
  #73
my year is a 2011 XJL with non adaptive headlights
Old Apr 23, 2019 | 02:28 PM
  #74
DnBnDTX's Avatar
Darealwoody,
How did your conversion go? I was curious as to if by the benefit of time could it be that this conversion can be done with the harness sold by CARID (I think) and then the OEM (or Slightly loved...OEM) assembly. I really would like to make the change, the posts for the retrofit quickly escape my current skill set. I think I can drop the bumper and unscrew the three bolts on each assembly. Dropping the bumper does scare me...a bit. But, I feel certain I could do that! A week ago, I replaced an HID bulb and that little incident cost $896.00...I could not imagine even discussing something like this with them!
Thanks in advance for sharing your adventures with us!!
BnDnDTX
Dallas, TX
Old May 21, 2019 | 01:19 AM
  #75
Toro's Avatar
Default Looking to buy headlights
Installation is in progress.
hello buy any chance do you sell your old headlights?
Old Nov 20, 2019 | 05:36 AM
  #76
alexis moreira's Avatar
Originally Posted by Franck Fabien
Hello, so I saw another electrician witch is very good!! this swap is very complicated than it sounds, the lights works except the ''cornering light'', no error on my dash (yet at least)
The process was a lot more than just pin swap!! the electrician had to cut some wires, had to put 2 relays each side and 1 load resistor each side. (Probably because here in the US its different, I was told that in europe they come wired with DRL lights)
I will do more test tomorrow and will post pics. Anyone interested in this mode in the New York area I can recommend a place, if you're else where, go see an electrician.
Frank I'm in queens ny trying to get this swap done where please!!
Old Nov 20, 2019 | 05:43 AM
  #77
Default Help pleaae
here are my 2 cats, 2012 on the right, and 2014 S/C with the headlight upgrade. Fitment is perfect, headlight leveling and everything works, except the cornering lights.
Here are the extra photos for the wiring inside and the extra relays added. I don't really know much about the wiring set up but this is the final result.
Who did it for you frank in queens ny
Old Nov 21, 2019 | 07:37 AM
  #78
Franck Fabien's Avatar
google ramesh & son (rockaway area)
email me if you cant find it. Or you can just copy mine if you want. Franckrandria@me.com
Old Nov 28, 2020 | 09:38 PM
  #79
RTJ 504's Avatar
where did u purchase your headlights
faiswish
Sep 8, 2019 12:06 PM
workworkwork
Dec 11, 2015 11:58 AM
n8ertot
Oct 13, 2015 06:15 PM
sugarsack
Oct 13, 2015 11:31 AM
BobRoy
Oct 11, 2015 01:32 PM
