XJ ( X351 ) 2009 - 2019
AFS (Adaptive Frontlighting System) Retrofit
Old Aug 26, 2022 | 01:51 AM
gloriashield's Avatar
Default AFS (Adaptive Frontlighting System) Retrofit
My Jag does not have an AFS(Adative Frontlighting System). A good opportunity came up for me and I took on the challenge of AFS Retrofit. If I sell my NON-AFS LED headlamps, I expected that the actual cost would not be expensive. The left is the same as mine, and the right is the newly purchased AFS headlamp.
I thought it was an easy job. Two headlamps and an HCM are needed. Some wiring was required, but not much. I wanted to work in similar to the genuine product as much as possible.
I bought a used HCM because I needed a jack. Of course I knew this HCM wouldn't work in.
Wiring harness diagram.
CCF editing and Software download for HCM.
Finally!
Old Aug 28, 2022 | 03:43 AM
MoJo88's Avatar
Nice! But have you actually tested your cornering lights? Because changing one parameter isn't enough.
Old Aug 28, 2022 | 07:15 AM
Default VBF mod for AFS
Actually, 5 values were changed. Corner lamps are working very well.
Old Aug 28, 2022 | 10:23 AM
MoJo88's Avatar
Good work. I was going off of the image you posted with only one change.
Adaptive Headlights are really useful at night on country lanes.
Old Sep 17, 2022 | 09:11 AM
Yes! Yes! Yes! Yes!
Old Sep 18, 2022 | 10:00 AM
clubairth1's Avatar
Community Influencer
Interesting to see you have a leaper in the cornering lights? I swapped to LED headlights on my 2014 XJR and got everything working but mine have no leaper?
Maybe it's only in certain markets?
Old Sep 19, 2022 | 12:36 AM
well... are the cornering ramps not working? LED headlights are clear. If it don't have a leaper, there's an AFS/Cornering lamp, 100%.
Old Sep 19, 2022 | 04:56 AM
MoJo88's Avatar
He was showing the difference between a non-AFS headlight and an AFS headlight.
Old Sep 19, 2022 | 09:15 AM
clubairth1's Avatar
OK so the non AFS lights have the leaper? I guess maybe a non-AFS car is very rare in the US because I have never seen a leaper in that spot. Looks good too!
Old Sep 19, 2022 | 10:25 AM
MoJo88's Avatar
Yes. It's the same with some of the other models such as the X250.
Old Sep 19, 2022 | 10:34 AM
clubairth1's Avatar
Good to know! Thank you.
Old Dec 1, 2023 | 01:14 PM
MichalM's Avatar
Default 7 Pin Frontlight.
Is it posible to have AFS with only 7 wires plug ??
Old Dec 1, 2023 | 01:27 PM
clubairth1's Avatar
I don't think so as my car (2014 XJR) has the 16 pin connections same as what gloriashield posted above.
Turko
Jul 23, 2025 09:23 PM
Mclovin22
Aug 14, 2022 12:22 PM
Z07Brandon
XJ220
Aug 11, 2017 04:02 PM
Mtuned
Jul 14, 2015 01:33 PM
Javier Mena
Europe
Feb 23, 2014 02:44 PM
