XJ ( X351 ) 2009 - 2019
Automatic trunk won't open
Old Dec 15, 2023 | 12:17 PM
JezuzNoChill's Avatar
Default Automatic trunk won't open
When you press any button inside the car key fob or the trunk it opens halfway - stops - and closes but doesn't latch. What should I try to fix it?
Old Dec 16, 2023 | 08:09 AM
IanXF's Avatar
Disconnect battery for 10 minutes recheck after that.
Old Jan 15, 2024 | 04:06 PM
So i took off some of the trim panels in the trunk and noticed that the wire on the right side hinge mechanism is rubbing the liner. But it's pretty much glued to the hinge so it looks factory and I couldn't position it any better so that it doesn't rub the liner.
gus13
May 22, 2021 11:10 PM
fredpribyl
XF (X260)
Dec 21, 2020 06:34 AM
tu2side
May 9, 2018 06:06 PM
anthem
Aug 31, 2015 02:01 PM
WVUBoss89
Nov 18, 2013 11:23 PM
