XJ ( X351 ) 2009 - 2019
brakes squeak
Old Apr 7, 2014 | 03:11 PM
Travis187's Avatar
Angry brakes squeak
Good morning I have a supercharge Xf The brakes squeak when coming to a stop...Someone told me I had Permanent Brakes?? can I get the system replace or just live with the squeak..
Old Apr 7, 2014 | 03:42 PM
Brutal's Avatar
Permanent brakes?? Thats a new one. Earlier years have a new brake spring avail to increase tension for noise. Call dealer and ask if avail for your vin since you dont list yr. And light frequent brake application(aka braking like a girl) glazes the pads and rotors and creats squeeling on most semi metallic brake equiped cars, find a deserted road and drive backwards in reverse and hit the brakes hard 2-3 times helps to clean glazing. then change your braking habits
Old Apr 7, 2014 | 04:01 PM
Jagfixer's Avatar
Could use some mileage and year and if pads have been changed recently.
Old Apr 8, 2014 | 01:00 PM
LiquidIce's Avatar
Thanks mate..out of curiousity, why drive "backwards" and not forwards?
Old Apr 9, 2014 | 11:39 AM
Brutal's Avatar
because its fun
actually Ive found that reversing the braking direction tends to work the best at cleaning the pads, and its alot easier than taking off the pads and rotors and swapping them side to side
flyrr100
Sep 29, 2015 03:47 PM
xjrjag
Sep 24, 2015 10:08 PM
wannajag
Sep 22, 2015 08:29 PM
Jefro
Sep 15, 2015 01:44 PM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
