XJ ( X351 ) 2009 - 2019
Bushings Bad and Motor Mounts needed replacing at 40k miles?
Old Jul 29, 2021 | 09:26 AM
demiroquai's Avatar
Default Bushings Bad and Motor Mounts needed replacing at 40k miles?
So I took my car last week to Jaguar in Mission Viejo because I would hear a clunking noise when I would go over speed bumps or down dips. Turns out my lower arm bushings were bad and needed to be replaced. What they also found while it was there was that my motor mount was bad. I was able to replace both of them but you can see my engine really move when you hit the gas.
Is this a common problem for a car with such a few miles? I’ve already replaced the water pump last year and I go in for regular maintenance every 15,000 miles.
Old Jul 29, 2021 | 10:32 AM
XJsss's Avatar
Did the dealer install the motor mounts? As it looks like the retention band that raps around the the motor mount may have been removed. I can't be %100 sure on this but others may chime in as that IMHO is way to much movement. could even be a missing nut holding the motor mount is missing.
Old Jul 29, 2021 | 11:57 AM
clubairth1's Avatar
Community Influencer
Now that is some engine movement right there!! Follow up with what XJsss said too.
Also check your transmission mount. It has been thru a lot with all that engine movement. They are easy to replace and often are found to be bad when the engine mounts are replaced.
Old Jul 30, 2021 | 07:19 AM
Ken Dreger's Avatar
Yep, that thing looks like it is trying to jump out of the engine compartment! Major issue......
Old Nov 4, 2022 | 08:16 PM
Tiger314's Avatar
Default What was the solution?
Demiroquai -
I'm in Newport Beach and have the exact same issue. I'm thinking of replacing both motor mounts. What did MV Jag end up doing to fix the issue?
Thanks,
Don
Old Nov 5, 2022 | 12:34 PM
NBCat's Avatar
Another common failure point on the X351 is the transmission mount, which can cause clicking/knocking noises when the vehicle is put into gear.
Old Nov 5, 2022 | 06:24 PM
George05's Avatar
Do you have any warranty on the car . Could try jaguar crc but they are trouble to deal with , good luck
Old Nov 5, 2022 | 08:15 PM
12jagmark's Avatar
Inexpensive part and not too hard to replace for someone that is comfortable working under the care though.
I thought it was odd that the OP was questioning the mileage, but never said what year/how old it was.
Not all parts are mileage-sensitive as much as age and impacted environmental wear.
Jeffrey David Benson
Jun 2, 2021 07:27 AM
Supercharged Jag
Sep 25, 2020 12:54 PM
chasman
Jan 27, 2015 02:23 AM
Cabezagrande
Sep 18, 2014 01:06 PM
yeshaib
Mar 21, 2014 08:48 AM
