XJ ( X351 ) 2009 - 2019
c2d2077 speakers
Old May 26, 2020 | 02:32 PM
Chris32111's Avatar
Default c2d2077 speakers
looking to upgrade my subwoofers but dont want to buy factory! anyone know what size speakers c2d2077 are? or what i can replace them with ?
Old May 27, 2020 | 08:50 AM
amlarson2001's Avatar
I believe they are 10 inch. Not sure what you can replace them with.
Old May 27, 2020 | 09:10 AM
clubairth1's Avatar
Community Influencer
No those are 200mm or 8 inch speakers. Search on your part number and you will see that.
I am in the process of replacing them with the stock reference drivers that have Kevlar cones.
Old May 27, 2020 | 09:26 AM
Chris32111's Avatar
send pics when done!!
Old May 27, 2020 | 09:29 AM
Your right they are 8 inch. I guess I just wish they were 10's or 12's would be even better
Old May 27, 2020 | 10:26 AM
clubairth1's Avatar
Yea me too but I looked at upgrading the rear doors which have 165mm speakers to the 200mm versions and it's just way too much work.
I am sure someone can do it but it won't be me!
Not much to show for the upgrade as the Kevlar cones are just black so they don't look much different from what I am replacing.
I have read reports of improved sound and found the 200mm ones for a good price so decided to try what others have already done.
One thing to note is the stock speakers are 2 ohm and the reference Kevlar drivers are 4 ohm. But in operation no one has noticed any reduction in volume.
Plus with keeping to the stock sizes and also being Jaguar it's a real simple swap. Remove the door cards and a couple of screws to swap the speakers out and the electrical plug is the same too.
200mm are 8 inch and 165mm are 6.5 inch speakers.
Old May 30, 2020 | 03:06 AM
SovietKitsch's Avatar
I have noticed in my 2011 that I need to raise the volume up more to get the same effect, but they do sound so much better.
I've also somehow made it so you can't lock the doors while taking the door cards off, so I need to fix that as well..
It's not as simple as it seems!
Old May 30, 2020 | 01:57 PM
clubairth1's Avatar
Lets hope I don't run into that when I do my swap!!
Old Jun 12, 2020 | 08:55 AM
Chris32111's Avatar
i know the back subs on the car are 8 inches as well. my question is do i need shallow mount speakers for the truck subs??? looking to upgrade those .
Old Jun 12, 2020 | 09:49 AM
clubairth1's Avatar
I am putting the 200mm Kevlar drivers in so they fit OK. But they are extremely flat for woofers plus only 8 inch.
Do you want to use after market equipment?
Old Jun 12, 2020 | 10:00 AM
Chris32111's Avatar
yes i want to use after market, can you take a picture of the subs you are putting in so i can rough see how flat they are?
Old Jun 12, 2020 | 02:53 PM
clubairth1's Avatar
Here is a thread with pictures showing all the options for speakers.
It's on the F-Type forum and it's a long thread so scroll to the pictures.
Speakers
Oops! Here is a better thread showing the thickness. Not much to work with!
I have not read where anyone found a replacement.
More Speakers
JJags
Dec 31, 2012 09:54 PM
tford
Audio/Visual Electronics
Jul 22, 2011 06:56 AM
85_305
Feb 5, 2010 04:15 PM
unboxed9
Jan 28, 2010 05:00 PM
