F-Type Stereo System Upgrade Planning
Old Mar 4, 2018 | 06:04 AM
  #61
Cambo's Avatar
The 100mm midrange speakers are paper/rubber in the F-Type.
The 200mm bass speakers in the F-Type 380W and 770W look like that, with the metal frame.
Old Mar 4, 2018 | 06:24 AM
  #62
jaguny's Avatar
Thanks again Cambo! After rereading and looking at older threads I think I have all info.
Old Mar 5, 2018 | 11:19 AM
  #63
langjag's Avatar
Thank you for all this great info. Is it possible to swap out factory speakers with aftermarket (Focal) without causing any other issues?
Old Mar 5, 2018 | 04:49 PM
  #64
Jeremy Gold's Avatar
Default System Change
So.... after some further planning and a few snags ... I had to change some items... for the better
I received the morel elate 903, but the x-overs were the 2 way and I can't get the 3 way x-overs without spending a lot of money. So I will have to run them active. This means another amp. Since I really like the audison thesis.... I'll shell out the dough for another Quattro. This provides me with a total of 8 channels (2 extra for subs if I choose).
the other change I made to materials is replacing the JL fix with a Mobridge da1. This module will take the digital signal right from the head unit straight into the bitone dsp and continue digital into the amps. The da1 was double the money of the jlfix... But I think we'll worth it.
I start the install of the speakers this weekend. Will take a while as I need to deaden 100% of the door, build the 9" speaker adaptors, mount the mid (hopefully direct fit) and the tweeter both sides.
pictures to come. Maybe a video as well
Old Mar 5, 2018 | 06:09 PM
  #65
jaguny's Avatar
[QUOTE=Cambo;1851800]One other thing I forgot to mention.
The front door 200mm bass speakers from the XJ 2010-2012 "B&W" system are also a straight swap into the F-Type.
Cambo, from what I was able to find the part number 200 mm B&W system from 10-12 XJ is 2CD2077. Is that correct? Also are there any direct swaps for behind seat woofers and smaller (midrange?) speakers above from earlier B&W systems?
Old Mar 7, 2018 | 01:19 PM
  #66
kurtomatic's Avatar
Originally Posted by Cambo
The speakers in the F-Type 380W Meridian and 770W Meridian Surround are all the same. Only difference is the Surround gets the additional coaxial surround speaker in the dash.
Presumably, then, the 380W system is equally compatible with these JLR speaker upgrades?
I'm fine with the 380W amp, but if there is a reasonably practical upgrade path for the speakers, I am all over that.
Old Mar 10, 2018 | 04:08 AM
  #67
Paul Calvert's Avatar
Just ordered the LR047119. For those searching on ebay, the label on the side of the speaker looks like this:
Old Mar 10, 2018 | 06:32 AM
  #68
jaguny's Avatar
How long before you replace the existing speakers? Who will do this?
Old Mar 11, 2018 | 04:42 PM
  #69
Default Jag Audio upgrade
here's my video
Old Mar 11, 2018 | 06:08 PM
  #70
Default Stage 2 video
Stage 2 video. Amp access and wiring
Old Mar 11, 2018 | 06:50 PM
  #71
jaguny's Avatar
Jeremy, great video to see the inner workings of the door. I was hoping to see how you removed the door pane, and which tools from your kit you used. You did say it only took five minutes. If I was doing the swap with oem upgrades I was wondering if I could tackle this myself or leave it to a pro. I expect you have removed car panels before and this isn't your first rodeo?
Old Mar 11, 2018 | 07:32 PM
  #72
Hmmmm. Is this is your first attempt, I'd say get someone who has experience doing this to walk you through it.
I've removed many door panels, so I felt pretty confident. They are all kinda simular.
you'll need a pick to remove the screw cap in the center of the door handle. This will reveal a t20 torx.
there's also another trim piece on the side of the door. I used my trim panel plastic tool to remove that (there's a video on you tube) that will reveal another t20.
two other square covers on the bottom of the door will reveal 2 more t20 screws
finally 2 t30's in the door grip.
once all 6 screws are out.... use a 90 degree trim tool to pull the bottom of the door out. Once you get it started, you can just use your hands to finish pulling the rest of the door outwards.
Hope that helps
Old Mar 11, 2018 | 07:44 PM
  #73
OzXFR's Avatar
Hope that helps
Yep, just as Jeremy says.
Here's the extract from the Workshop Manual:
File Type: pdf
Old Mar 12, 2018 | 06:42 AM
  #74
jaguny's Avatar
Thanks Gents, very helpful. Workshop manual spells it out and with Jeremy's video it seems doable, but I will need to assess if it's worth the risk. Oz, where did you buy the workshop manual? Would be nice to have one regardless.
Old Mar 12, 2018 | 08:31 AM
  #75
OzXFR's Avatar
I and a few others got one a year or so ago, tailor made for our particular VINs, but shortly afterwards the supplier stopped doing Jaguar manuals.
However I have put a "sanitised" copy of mine in my Dropbox, go to this thread and use the second link in post #1 to download it: https://www.jaguarforums.com/forum/f...orkshop+manual
It's for a MY2015 V6S coupe auto but it will still be 99% applicable to your car.
Old Mar 12, 2018 | 05:53 PM
  #76
jaguny's Avatar
Oz, thanks much. I downloaded it; lots of info, should be very useful!
Old Mar 12, 2018 | 07:42 PM
  #77
Cambo's Avatar
Focal makes a 200mm "subwoofer" for BMW's that is the same size/shape as the door bass speakers. But they are double the price of the Meridian Signature ones from JLR. I haven't seen 100mm midrange speakers from Focal available individually, only in splits kits. Just my opinion, but I don't see the value in Focals for these cars.
Yes.
The "B&W" 200mm from the XJ are C2D2077 / AW93-18808-CB, I really could not tell you if they are better or worse than the Meridian Signature ones though.
Not that i'm aware of, they are unique assemblies to the F-Type, and not meant to come apart either by the looks of things.
Only problem with the Mobridge is you can't use the Surround modes, so if you had a 770W Surround System, the Surround mode button get's frozen. If you were starting with a 380W or Base system, it's no big deal.
Old Mar 13, 2018 | 05:16 PM
  #78
jaguny's Avatar
I have a ballpark estimate of $200 for a shop to pull the door panels and remove the 3 door speakers and install the B&Ws from the 2010-2012 XJ. Speakers are about $525 for all six plus tax and shipping from a jag dealer. I think I'm going this route.
Old Mar 13, 2018 | 06:34 PM
  #79
mlebofsky's Avatar
Personally I would love for someone to crack/hack the Meridian firmware so we can tweak/tune ....
Old Mar 13, 2018 | 07:14 PM
  #80
JgaXkr's Avatar
Please keep us posted as I am quite interested in how much of an upgrade it is.
