XJ ( X351 ) 2009 - 2019
Check engine
Old Jun 24, 2018 | 12:53 AM
Raman Punjabi's Avatar
Default Check engine
Hi
last week while driving my xj v8 petrol the check engine light popped up upon scanning it said bank 1 and bank 2 too rich , got the error cleared but they again popped back after driving for about 15 minutes. Please advice me where to start .
I check petrol cap it’s fine so are the oxygen sensors
Old Jun 24, 2018 | 07:28 AM
Thermo's Avatar
Veteran: Navy
Raman, you got the codes read, what were the codes? This will give us a fair amount of info as to what your problem may be. Just to say that the car is running rich can be a number of things. Getting a code like P0305 would be very helpful as that would tell me you have a problem with cylinder #5 and mixing that with the rich code would tell me that it is either a stuck fuel injector or a coil that is bad (most likely suspects). So, if you can, post the codes here and we can take things from there. Right now, there are too many possibilities as to what the problem could be.
Old Jun 24, 2018 | 10:18 AM
Hi
The code I got was p 0174
Old Jun 24, 2018 | 05:37 PM
Thermo's Avatar
Veteran: Navy
Raman, P0174 is an indication that you have a vacuum leak on the Bank 2 side of the engine. If you open the hood/bonnet of the car and look at the engine, it will be the cylinders on your right side. As to what will cause this issue, the most likely thing is the intake gaskets. This is where blowing a little bit of smoke into the engine bay when the motor is cold and the A/C is turned off will allow you to find the vacuum leak. You want the fan to not be running on the car (hence why the motor should be cold and the A/C turned off) and then you blow the smoke into the engine bay in a limited area. Watch the smoke to see where the smoke is slowly wandering through the engine bay and then makes a sudden change in direction and speeds up. This will point to where the vacuum leak is.
By chance, what year is your XJ?
Old Jun 24, 2018 | 09:06 PM
Stuart S's Avatar
It's a 2011 XJL 5.0L, per his Personal Profile.
Old Jun 24, 2018 | 09:17 PM
Thank u Thermo
my car is a 2011 xjl 5000cc v8 petrol
Newjag
Feb 4, 2019 12:10 AM
kmmoore1013
Jul 28, 2013 04:31 PM
srpope80
Nov 17, 2011 04:06 PM
Viapa
Jan 9, 2011 09:49 PM
rh99XK8
Nov 20, 2010 05:37 PM
