XJ ( X351 ) 2009 - 2019
Confused about ride level sensor connector
Old Aug 25, 2020 | 08:02 AM
LukeShopManager's Avatar
Question Confused about ride level sensor connector
Hello all! I'm a shop manager at a Euro shop in CT. We have a 2011 XJ Supercharged that a customer brought in. It appears as though it was in a front end collision and the right front ride level sensor is broken and needs replacement. The connector is broken and my techs and I are stumped on the pin out since some genius at a previous shop decided to use all red wires and presumably wired it wrong. All the diagrams I can find say that there are only supposed to be 3 wires in the connector. Pin 1 is ground, Pin 4 is signal, and Pin 5 is 5V reference. We cannot figure out why there are 6 wires going to the sensor. Does anyone know what pins 2,3, and 6 do? We want to get this wired right but can't proceed without a further understanding of wire colors and pins. Any help is appreciated, thanks! -LukeShopManager
Old Aug 25, 2020 | 04:37 PM
Thermo's Avatar
Veteran: Navy
Luke, Wire for Pin 2 is a green-brown wire that is the reference voltage ground. Pin 3 is a yellow-green wire that is the reference voltage source. Pin 6 is a brown wire is the output of the sensor to tell the computer how high the car is sitting. This would be for 1 of the height sensors. Wires 1, 4, and 5 are for the other height sensor in that block (there are 2 sensors in the one block/module). Just to make sure you have the right wiring, wire 1 is a brown-blue wire that is the reference ground. Wire 4 is a white-green wire that is the sensor output. Wire 5 is a yellow-green wire that is your reference voltage.
Hope this helps.
Old Aug 26, 2020 | 06:44 AM
Thank you for the reply. That's incredibly informative. Fingers crossed that the colors you listed are indeed the ones on the harness. We'll be putting the car on the lift again soon to verify. I really appreciate the help!
Old Aug 26, 2020 | 06:55 AM
Rummy636's Avatar
If you can give some more info i can probably get correct for vehicle. Some wiring can be different depending on air suspension or CVD suspension.
Old Aug 27, 2020 | 06:22 AM
Thermo's advice worked, we got it properly hooked up and no more error. Thank you for the help!
Old Aug 27, 2020 | 12:00 PM
Thermo's Avatar
Veteran: Navy
Luke, not a problem. Stick around, you will find us a critical asset for you.
Old Jul 3, 2021 | 05:55 AM
khalidmalik9016's Avatar
Hope this helps.
hello
km here
im a car enthusiast who has had to learn how to fix my cars myself cuz theres very few of these jags here and no trained personnel.
so my problem is the same as above except i need the wiring for the left hand side front. any help would be appreciated. regards
Old Jul 3, 2021 | 06:09 AM
can i please be provided with the color codes for front left sensor
Old Feb 15, 2023 | 07:53 AM
STRXJL's Avatar
Default Part number
Digging up an old thread .....but does anyone know the part number for the connector itself?
I have the exact same problem.... broken RH sensor connector.
sawduster
Nov 6, 2019 03:14 PM
95Leaper
XJ40 ( XJ81 )
17
Feb 26, 2017 08:27 PM
woody258
Apr 8, 2015 06:16 PM
Robert
XJ40 ( XJ81 )
Jan 6, 2013 04:04 AM
MRomanik
May 23, 2012 02:06 AM
