XJ ( X351 ) 2009 - 2019
Coolant Hose Under Supercharger?
Old Aug 2, 2023 | 06:27 AM
griff831's Avatar
Default Coolant Hose Under Supercharger?
I am planning an overhaul of my 2013 XJ 3.0 AWD soon including coolant pump, pipes, hoses, and supercharger snout replacement. I have had a lot of difficulty in the manuals and parts diagrams identifying the hose that is routed underneath the supercharger.
could someone tell me the part number? I want to replace if I’m in there. Thanks in advance!
Attached is an example image from the F-Type V6 supercharger removal tutorial:
https://www.jaguarforums.com/forum/f...tailed-241371/
Old Aug 2, 2023 | 10:17 AM
12jagmark's Avatar
I think that might be C2Z28432.
BUT first, search that part number, or call a dealership & tell them you need the part # for the hose that goes from the rear heater manifold (or cross-over pipe) to the throttle body.
...to make sure it's the one. It's one of the 2 throttle body hoses, & I believe that is the long one that runs under the intake manifold.
UPDATE - I just put eyes on one I have and I'm sure that's the one, but do your own confirmation anyway.
Old Aug 2, 2023 | 02:49 PM
griff831's Avatar
Thanks, 12jagmark!
I attempted to look up the matching 3.0 V6 hose but had to call the dealer instead. They gave me this part number for the throttle body hose. Hopefully this is what I need, it’s in the mail later this week.
C2Z18677
Old Aug 2, 2023 | 04:57 PM
12jagmark's Avatar
Arggh- Sorry about that. I looked in haste & didn't think about the 6 cylinder probably being a little shorter then the V8 hose.
Old Aug 6, 2023 | 07:30 PM
griff831's Avatar
Oh my goodness, removing the supercharger from the engine intake was a piece of work! I ended up cracking one of the clips that hold this hose to the underside of the supercharger…it was baked pretty good I bet, one touch of my pliers did her in. Hopefully it’ll be ok! I’ll plan to zip tie to the rear heater manifold to prop it up a bit.
Old Aug 6, 2023 | 09:27 PM
12jagmark's Avatar
I'd assume a new clip comes with the hose as it does with the V8 hose anyway.
Old Apr 13, 2024 | 12:08 PM
Flyhayes's Avatar
The clip broke off of mine when I took off the blower.
Can anyone confirm if the new hose does indeed come with the clips attached?
Much appreciated!
Old Apr 13, 2024 | 12:12 PM
griff831's Avatar
Much appreciated!
Hi this is the part number, and no it does not come with either of the two clips:
  • C2Z22073 Lower Cooler Hose to Thermostat (under supercharger)
I used a black zip tie on the back side to the rear heater manifold to lift up this hose since the back clip broke. I would definitely order both clips if you can find the part number. Not a place to zip tie on the front.
Old Apr 13, 2024 | 12:17 PM
Flyhayes's Avatar
Thanks for the speedy reply. The hunt will continue for the clip part numbers. I'll report back if I figure it out.
Old Apr 13, 2024 | 12:20 PM
griff831's Avatar
I would look into the supercharger assembly part numbers.
Old Apr 13, 2024 | 12:59 PM
Flyhayes's Avatar
After some searching it appears the clips are part number C2P14812
Old Apr 14, 2024 | 10:28 AM
lotusespritse's Avatar
Originally Posted by flyhayes
after some searching it appears the clips are part number c2p14812
page not found
Old Apr 14, 2024 | 11:17 AM
clubairth1's Avatar
Community Influencer
Here is a picture of it.
Jaguar Clip
Looks like about $2.50 and is a current good part number at any dealer.
Old Apr 14, 2024 | 12:35 PM
Flyhayes's Avatar
Originally Posted by lotusespritse
page not found
Sorry I didn't realize it was copied as a hyper link. The part number itself is correct though
bcbruno
Jun 17, 2023 11:24 PM
Mike1967
Jan 25, 2023 01:57 PM
kr98664
Dec 31, 2022 01:56 PM
Razorbladehaze
Apr 30, 2018 09:05 AM
