XJ ( X351 ) 2009 - 2019
Coolant leak 2011 Jaguar x351 5.0 N/A
Old Jul 16, 2022 | 08:04 AM
Dodenhoff74's Avatar
Default Coolant leak 2011 Jaguar x351 5.0 N/A
90k miles, had low coolant warning.
came home and filled up resivour, engine seems fine.
Took air intake off and the leak is coming from the front of the engine somewhere.
https://youtube.com/shorts/VQAXymvozhQ?feature=share
Old Jul 16, 2022 | 08:11 AM
Thermo's Avatar
Veteran: Navy
Dodenhoff74, odds are, you have a leak from the tube that joins the water pump to the oil cooler. This is a small plastic part that will catastrophically fail due to temperature cycles, making it become brittle (ask me how I know). It is possible that it could be one of the other plastic parts connected to the water pump (there are a few, but the small tube is the most likely). Your best bet at this point is to not drive the car (very easy to overheat these engines and can lead to catastrophic engine damage) and get it in to have a new water pump put in with the upgraded plastic components. There is an upgrade that you can do for the little plastic piece between the water pump and oil cooler that you can get a metal piece there. Yes, it is a few dollars more, but it will be money well spent. A local shop should be able to do this job for you. But, plan on spending about $1500 USD.
Old Jul 16, 2022 | 08:48 AM
After watching a few videos and looking for the leak I believe the engine oil cooler pipe is the culprit. Hopefully I didn't damage the engine when it did overheat. I saw the temp gauge got to about 3/4 and within two minutes pulled in and filled the resivour. I've let it idle about 30 minutes while watching the coolant and the engine sounds fine. Hopefully I didn't damage it
Old Jul 19, 2022 | 12:46 AM
fossberry's Avatar
Hopefully you allowed the engine to fully cool before refilling.
Old Jul 24, 2022 | 05:51 PM
leaddog11's Avatar
Anyone have the part number for
Daneel227
Aug 5, 2021 11:06 AM
Aceman123
Mar 3, 2021 02:15 PM
Ken2839
Oct 3, 2016 09:42 PM
Drak
Dec 11, 2015 03:45 PM
sinatrakat
Sep 13, 2010 04:20 AM
