XJ ( X351 ) 2009 - 2019
Coolwater
Old Jun 15, 2017 | 09:34 AM
V8 Power's Avatar
Default Coolwater
I need help. what could that be. Water pump is new.
Old Jun 16, 2017 | 08:25 AM
Paulc732's Avatar
V8,
When you changed your pump did you also change parts 4 and 5?
check out this thread,
https://www.jaguarforums.com/forum/x...s-list-177921/
Old Jun 16, 2017 | 08:35 AM
V8 Power's Avatar
Yes, was also changed.
Old Jun 16, 2017 | 08:38 AM
V8 Power's Avatar
It flows out a lot.
Old Jun 16, 2017 | 08:57 AM
Paulc732's Avatar
V8,
I had the same problem.
when you fitted the new pump were you careful about getting the pipe in the back seated properly?
when i fitted mine the first time i missaligned the pump and pushed the pipe to one side so had the same water flow you are seeing.
just to check you changed 2 O rings
hate to say it but you will have to pull the pump off again and check.
Please follow this link new-member-area-intro-must/ forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Jun 16, 2017 | 10:23 AM
V8 Power's Avatar
No, pump sits right. Had used new O rings. I suspect that the outlet pipe (AJ89664) is defective. I believe the suction bridge must go down.
Old Jun 16, 2017 | 11:37 AM
Paulc732's Avatar
Yeah I ended up replacing mine,
not a hard job but I recommend getting some of these if your going to remove the intake
Uxcell Nylon Auto Car Dome Fir Tree Mount Cable Tie, 183mmx5mm, 30 Pcs, Black
What year and how many miles on your car?
Old Jun 16, 2017 | 12:47 PM
V8 Power's Avatar
2010 80000 miles
Old Jun 17, 2017 | 05:52 PM
Paulc732's Avatar
V8 I had to change mine at 58000 miles so it might be a good idea to change.
Do you do the upgraded piping there is a parts list in the post I sent you in #2
https://www.jaguarforums.com/forum/x...lwater-183967/
Old Jun 18, 2017 | 12:50 PM
V8 Power's Avatar
Today I got a picture of the workshop outlet pipe was broken.
Old Jun 20, 2017 | 12:48 AM
V8 Power's Avatar
So guys he's running again
