XJ ( X351 ) 2009 - 2019
Dashboard going crazy adaptive dynamics, abs fault , speed not reading at times
Old Jun 29, 2021 | 01:30 AM
Unclereggie's Avatar
Default Dashboard going crazy adaptive dynamics, abs fault , speed not reading at times
Hey guys okay so I have a 2011 xj , I’ll begin where I think the problem started after a few pulls & races my front end gets an absolutely awful shake through the wheel under heavy braking or light braking , I assume my rotors are bad ? They look absolutely fine .. any who after this one time the shake probably was the worst it’s ever been . as I’m getting off the interstate I get an abs light (drive with care ) emergency stop assist not available , as well as parking brake not available. I get home then go out the next day no lights until halfway into my commute it went away after restart.... I fill up the tank than get on the interstate to take a 150 or so mile drive & and the dash goes insane . Throwing what looked like every warning it could , all the while it drove completely fine no hiccups , battery is strong . No loose or mast connections , here’s a video .......tonight I went on a drive and not once did anything pop up , any ides ? I have a Chevy express that did the same thing .it fixed it self because it’s been months since the van had a hiccup
Old Jul 4, 2021 | 09:28 PM
mc690's Avatar
Default Could be Speed Sensor
The shimmy when stopping is usually brake related but the speed sensors on all 4 wheels can fail and they affect cruise control, ABS, all the driving & stability modes including traction control. I had my driver’s front go bad on my ‘09 XF. Wasn’t expensive labor/part wise. (A caveat, I bought a used part based on condition AND a guarantee!)
Old Mar 8, 2023 | 05:30 AM
dmslater20's Avatar
Did you ever resolve this issue, if so can you kindly share.
sdettra
Sep 3, 2013 06:29 AM
OldMike
Jul 22, 2013 07:22 PM
jgoode
Aug 16, 2012 07:42 AM
Greg561
May 19, 2009 08:07 PM
