XJ ( X351 ) 2009 - 2019
Did I do that? Hubs/ bearings all failing.
Old Feb 5, 2019 | 08:01 PM
Nedoerr's Avatar
Default Did I do that? Hubs/ bearings all failing.
Hi all,
I recently did my first brake job ever and it appeared to go pretty well. However over the past month, two rear hubs have needed replacement and now a third one (passenger front) appears to need replacement. It seems too coincidental to ignore the prospect that I damaged the hubs during the brake job. I did use a 4lb dead-blow hammer to remove the rotors as they were stuck on to the hub. I didn’t think I hit them very hard. Does anyone have any thoughts/ experience with this? Is it easy to damage a hub/ bearing with a hammer?
Thanks.
Old Feb 5, 2019 | 08:09 PM
Thermo's Avatar
Veteran: Navy
Nedoerr, it is possible, granted, I would think that you would do more damage from hitting potholes, especially if you are running a wider tire and/or a rim that does not have the factory offset (or has a spacer between the rim and the hub). I have used a hammer to take off rotors and can't say that I have ever needed to replace a hub shortly thereafter. Granted, I tend to also throw in some rust dissolver fluid and to strike my way around the rotor to ensure whatever play I create can be used to get more movement with the next strike. The big question becomes how hard did you hit it. This is very subjective and it is possible that if you have bad roads around where you live, you didn't do the hubs any good by beating the rotors off. I would think that if you hit the rotor hard enough to have caused damage, you would have had some play in the hub when you put the wheel back on and would have probably noticed that.
Old Feb 5, 2019 | 11:00 PM
Nedoerr's Avatar
I didn’t notice anything wrong until 200 miles after doing the brakes. It initially drove smooth and quiet. I have stock Jaguar rims and recommended tires.
The hubs have never been replaced before and I’m now at ~83000 miles. So maybe they were just due. It’s just been tough having the car at the mechanic every other week (for urgent repairs I just take it in). Hopefully this won’t happen again on my next brake job.
Thanks for your thoughts.
Old Feb 6, 2019 | 12:54 PM
SinF's Avatar
Two maybe a coincidence, three is a pattern.
Old Feb 8, 2019 | 10:31 PM
Nedoerr's Avatar
Turns out it was likely bad luck on the third one. I must have hit a major pothole because my rim also got badly bent. I thought the car was driving very poorly. Despite the bad news about the rim, it was nice to see such an obvious wobble when they put it on the wheel balancer. When the rim is repaired I should be back to smooth riding.
Unfortunately I will be without my car till Wednesday, and the local Jaguar club meets tomorrow. I’ll be showing up in my wife’s Honda CRV instead.
Old Feb 8, 2019 | 10:46 PM
BritCars's Avatar
I would suggest it's almost impossible to damage the hub in the normal course of rotor removal. Think how incredibly hard the forces are on the hub when a 2 ton car careering at 70mph hits a hard bump or pothole. There is no way you come close in rotor removal
At 80k plus you were probably just in need of replacement.
Old Feb 9, 2019 | 07:29 AM
Thermo's Avatar
Veteran: Navy
BritCars, when it comes to bearings, that is not quite the case. Bearings are really only meant to see forces in 1 direction (either in line with the shaft or perpendicular to the shaft). Taking stresses the other way (even small) can be damaging. In the case of wheel bearings, they do a little bit to make the bearing have characteristics of both (hence the sloped race inside the bearing). So, a wheel bearing/hub will have say 90% of its strength in the up/down direction so it can handle the weight of the car and hitting potholes and whatnot, but only 10% for sideways motions (ie, the stress of making the car turn, something brushing the side of the wheel/rim). So, it is much easier to hurt a hub hitting it from the side than to hit bumps in the road. I do agree that it would take some pretty good hits to hurt a hub, especially when trying to remove a rotor, but the more play you have in a bearing from wear, the easier it becomes.
The other thing to consider is that the tire flexes as you hit holes and whatnot. This helps to distribute the force over time. So, the shock is not as bad. Where , if you are taking a no bounce hammer and striking the rotor, there is no give. The shock of the hit is sent straight to the hub/bearing.
Old Feb 9, 2019 | 10:26 PM
BritCars's Avatar
Yes, that's probably fair. But I can only imagine that when driving in real world conditions with the suspension bouncing up and down, bumping over a road and turning corners that the lateral forces and bumps are pretty severe too. Many mechanics remove rotors with a good blow from a hammer, so I'd expect to see more caution if that could cause harm
So I guess your point is right that it's possible to harm them. It just seems very unlikely and certainly not an issue I've come across in the past
barking cricket
Jul 3, 2014 06:18 AM
Sparkers69
Aug 15, 2013 02:35 PM
WaterDragon
Aug 7, 2013 06:22 PM
Tijoe
Sep 19, 2011 10:19 PM
JimC64
Oct 4, 2007 05:27 AM
