XJ ( X351 ) 2009 - 2019
Dim DRL Lights Troubleshooting
Old Feb 1, 2025 | 01:47 PM
danu99's Avatar
Originally Posted by ocwolfy
Engine Compartment.
The xj has a lot of space in front of the engine compared to other cars I've worked on. Especially with the intake off. But you won't need to remove that.
Here's a video for better insight. I know we're not talking about replacing headlights but they can help you get a view. https://youtu.be/99uURzTF3kk?si=T6F1X1TzmDnBArCR
👍👍👍👍thanks man
Old Feb 1, 2025 | 01:54 PM
danu99's Avatar
Engine Compartment.
still…. Sorry for the inconvenience.…. One more question.
Unplugging the lights….. Battery disconected or not? Will it give a error?
Old Feb 1, 2025 | 02:05 PM
ocwolfy's Avatar
Yes, disconnect the battery and use electrical contact cleaner to clean pins on the headlights and the connection and wait for them to dry! If you use too much spray the liquid will linger until it dissipates.
Old Feb 1, 2025 | 03:05 PM
danu99's Avatar
👍👍👍Will do that. Thanks
Old Feb 3, 2025 | 06:26 AM
Jaaag_drivah's Avatar
These round headlight connectors are very prone to corrosion- mine has a weak connection on the pin that connects the right side turning lamps...it flickers and drives me absolutely crazy. May have to go in there this week and slightly bend the connector so it makes better contact...
arbud
Sep 5, 2024 06:46 PM
TN_Super_V8
Feb 24, 2023 07:45 PM
Ngaard
Nov 17, 2022 05:03 PM
Eduardo Miranda
Sep 3, 2019 03:01 AM
IanXF
Jul 19, 2012 02:37 PM
