XJ ( X351 ) 2009 - 2019
Double beep alert?
Old Aug 23, 2022 | 06:40 AM
elliotk's Avatar
Default Double beep alert?
I open the door to look out on to the ground lines while I back up into my parking space, some times I get this double beep without any warning lights on the dash. Any idea what the beep is for?
Took a video with the double beep at the end.
Old Aug 23, 2022 | 12:03 PM
clubairth1's Avatar
Community Influencer
My back up camera has lines on the screen? I use those as I can see the painted lines on the ground too.
Funny thing I just found out is some of the new pickups will not move if the drivers door is open. Safety feature.
Old Aug 23, 2022 | 03:56 PM
Vasara's Avatar
Not absolutely sure, but you might set your suspension accidently to the "tight tolerance mode" what are used for adjusting headlights. It went something like this: Open drivers door, press brake pedal 3 times inside of 2sek window, close drivers door - you get 2(?) chimes for confirm. Suspension go to normal mode in next start.
Like i wrote, i am not complete sure for this. Haved done it once, about 4 years ago, after i changed the bulbs.
Old Aug 24, 2022 | 04:42 AM
elliotk's Avatar
My parking space requires me to be exactly on the line to leave some space for the car next to me to open its doors. Welcome to Hong Kong, where every inch of space counts!
Old Aug 24, 2022 | 11:21 AM
clubairth1's Avatar
Any more info about the "tight tolerance mode"? I have adjusted my headlights but just parked the car on flat ground when I made the adjustments.
Does it lower the car?
Old Aug 24, 2022 | 11:37 AM
Vasara's Avatar
Hi. No it do not lower the vehicle, but set the rear suspension closer its initial height. In normal mode the height have wider tolerance berore suspension make corrective action for it.
Example, in normal mode you can sit in or step out and rear suspension will not correct the changed height. (well, depends how much you have collected "spares" on your weist or just happened to have big bones) Note: Only rear have air suspension in x351 model.
Jason.
Sep 25, 2021 12:23 AM
Georgina Hewitt
Apr 12, 2020 08:09 AM
madijag
Jun 14, 2017 01:22 PM
jamie whyte
Mar 1, 2013 03:15 AM
squish
Nov 22, 2010 05:52 PM
