XJ ( X351 ) 2009 - 2019
DRL ligts stay on
Old Jul 16, 2025 | 11:00 AM
TNLakeGuy's Avatar
Default DRL ligts stay on
After turning the car off a "Lights On" message appears. Doesn't matter if switch is in off or auto mode. DRL and rear lights stay on. I found that by putting the turn signal/lighting stalk in a left turn position turned the lights off.
Any suggestions?
Old Jul 17, 2025 | 05:18 AM
Jaaag_drivah's Avatar
There is a common issue with the lighting stalk where the wires will rub and it shorts out internally. Advise replacement of the lighting stalk with a good used part or you can open it up and repair it yourself. Do a forum search and there are a few threads about it.
Old Jul 17, 2025 | 09:11 AM
TNLakeGuy's Avatar
Thanks for the info! I'll see if I can take it apart and see where the wires are crossing before getting into a replacement part.
KellyJ1963
Mar 25, 2025 02:31 PM
talashek
Dec 22, 2024 01:40 PM
ThatXF
XF (X260)
Jun 20, 2021 03:37 PM
Sinbad
General Tech Help
Jan 29, 2020 09:42 AM
RacerXK
Dec 8, 2016 07:30 AM
