XJ ( X351 ) 2009 - 2019
Engine Shield Cover
Old Dec 12, 2023 | 05:16 PM
JaguarXJL15's Avatar
Default Engine Shield Cover
I can not get one of the screws of the engine shield cover to open it will just keep spinning I think the screw clip on the other side is rusted on the screw threads any ideas how to get it to unscrew I tired pulling the shield and other cover its screwed to apart while trying to unscrew did not work I tired for one 1 hour! nothing worked
I will try cutting the screw off with a bolt cutter
Old Dec 13, 2023 | 06:22 AM
2018XF25T's Avatar
You need this while you unscrew the clip. Or if you don't have any, a small screw driver will do
Old Dec 13, 2023 | 10:35 AM
clubairth1's Avatar
Community Influencer
My engine cover is just held on with rubber grommets? Pull up and they release?
Maybe I don't understand which cover your talking about?
Old Dec 13, 2023 | 12:03 PM
splash shield cover on the bottom
Old Dec 13, 2023 | 12:05 PM
its too rusted the screw will only become harder to turn simply cutting it off is best
Old Dec 15, 2023 | 07:51 AM
clubairth1's Avatar
Sorry I was thinking of the wrong thing.
Old Dec 15, 2023 | 09:40 AM
anyone know the part number for the 10mm bolts? they are all rusted
Old Dec 15, 2023 | 11:47 AM
Freddy J's Avatar
Go buy some stainless steel bolts and spray them with Boeshield and install them for the next time you want to get that cover off.
hawaii
Sep 18, 2016 04:29 PM
Adamjag
Oct 30, 2015 07:32 AM
philwarner
22
Sep 1, 2015 03:35 PM
Dadio
Dec 29, 2013 10:34 AM
Lug_Nut
Jul 26, 2012 03:05 PM
