XJ ( X351 ) 2009 - 2019
Flashing Lights
Old Jan 12, 2018 | 08:45 PM
Lovmxjl's Avatar
Unhappy Flashing Lights
I noticed on some of the older models this is a problem. I have a 2014 XJL LB-Rear WD. It has done this twice. Is this a warranty covered problem?
Old Jan 12, 2018 | 10:43 PM
rhomanski's Avatar
Anytime I see flashing lights there is usually a Policeman close by. I wish a warranty would cover them.
In your case I guess maybe you should say if you have a warranty and explain what's flashing?
Old Jan 13, 2018 | 10:21 AM
Lovmxjl's Avatar
Default Flashing lights
My flashing is my dashboard, all the warnings flash, the infotainment stops and has to find a signal again. The car doesn't cut off it pauses at that moment.
Old Jan 13, 2018 | 10:34 AM
Stuart S's Avatar
It should be covered if your 2014 is still under the original Jaguar new car warranty or Jaguar Select Certified Pre Owned warranty.
porschefixer
Jun 28, 2022 04:28 AM
chitownred
XJ40 ( XJ81 )
21
Jun 1, 2014 06:10 PM
obeymukie
Dec 28, 2010 05:56 PM
MissChelle
Feb 17, 2010 12:22 PM
