Front End Clunk
Trying to chase a soft front end clunk. I checked all arms and links and looks tight, no fluid leaks from the banana arm. The only thing that seems odd is when I disconnect the sway bar link and try to rattle the bar I hear a noise near bushings in the engine bay. I disconnected both sway bar links and I can slide the bar side to side and produce a contact noise. I wonder if this is normal, the bushings looks ok but I am limited on the visual. I can only source original jaguar bushings 45 a piece. Anyone replace these with a more durable aftermarket source? I’m not confident it will do it but the sway bar is the only part that creates a noise, although side to side is not it’s normal operation.
My first question is did you drive the vehicle with the sway bars disconnected to verify the noise is now gone? No need to be spending money on pieces if it wont fix your issue. Ive zip tied the bar out of the way so the bar doesnt hit during driving. I would only recommend quick road test through the neighborhood, not down a main route.
Sway bar bushings are a known issue for the clunking. Several forum members have used non OEM bushings with mixed results. As for me, mine were replaced under warranty many mile ago and solved the problem.
XJsss
Do you have a link to the alternatives so I can explore, The main issue is most aftermarket bushings don't have the cloth/fabric liner that the originals have, and need lubrication which can creak during winter months after the lube dries up. But if made of harder material like Poly sometimes it can slightly improve handling.
I have no info on the poly bushings, but have read in another thread that trying to lube the non OEM bushings did not work out. Can't remember the thread but it's been tried.
Thanks, I’ll look into it.
I changed my sway bar to XJR spec and swapped out my bushings for the power flex at the same time. It solved my soft clunking issue and I did initially get some squeaking on small ramps. I think I will lubricate next fall but now that it’s warming up here in WI I don’t have the noises anymore.
Have you read some of the recent previous posts on clunks and wobbles like you're describing? A lot of good info, and results of what others have replaced in search of the source.
What kind of fluid would you expect to see coming from the front "banana arm"? Do you have one that's filled with fluid?
I don’t know I thought I read they were liquid filled at the subframe. We’re there different iterations? Maybe I have the revised part? Things look pretty good up front when it comes to bushings and arms, the rear on the other hand is a disaster, torn ball joint rubber at the knuckle, at the toe link, and sway bar links, torn outer CV boots, and broken wheel nuts. But no noise just bad rubber boots.
Looking at parts the XJR sway in the front seem to be same as diameter as any XJ with the 5.0l SC and some of the Sport Pack V6s. So I believe I already have the larger bushing in my 5.0SC
Here is my measurement to my best ability. Unfortunately the Jaguar online parts is pointing me to the bigger bar but no measurements given just applications. Same goes for the aftermarket Genuine Brand and Febi brand. I am curious as to why that is.
30.20-30.30MM more or less. Different results at the center with limited space to get the caliper there. Inside the wheel it was a little smaller read. Obviously I am assuming the bushing area diameter is the same as the center of the bar.
I will assume the XJR is 31.30?
You can see the bushings that end in 49 applies to any 5.0SC Irrespective of XJR.
I get similar results looking at the bushing in the aftermarket under the Genuine brand, which i think are simply repackaged OE parts to be sold via other retailers.
Febi only sells the smaller 3.0l bushings.
