XJ ( X351 ) 2009 - 2019
G D IT! Again!
Old Apr 4, 2018 | 06:25 AM
JagGate's Avatar
Default G D IT! Again!
I was very happy last year playing Spotify through the XJ. Worked like a charm! I could start the app by simply moving to the Bluetooth connection and change songs and even see what song was playing. Then for some reason it simply stopped working. W T F! So I was resigned to listen to crap doo-doo radio. Tmobile recently sent an update out so for fun, I tried again. Success! I was once again happy with Spotify working perfect again. Then 2 days ago, it stopped working again. W T F x 2!!
When it stops working (this time and last time). The phone is connected. The phone sees the car and the car the phone. Phone calls work perfect. Phone thinks it is playing through car as it no longer makes noise on the phone. But I cannot hear anything and no data for song info transfers to car.
Does anyone on here have a clue what could be wrong?? I re-paired the BT, cleared the app cache, etc, etc, etc.
Makes no f'n sense at all.
Old Apr 4, 2018 | 09:36 AM
Ktmracing03's Avatar
From time to time in my spotify app I have to select playback devices and choose my XJR. Towards the bottom there is a white option that reads "Devices Available" click on that and it will bring up all the available devices then just pick your XJ and you should be good.
Old Apr 5, 2018 | 08:33 AM
JagGate's Avatar
So I found there is an "dual audio" setting in the BT for Samsung. This apparently is a known Samsung problem. I found that setting and it is working again. I can't start it anymore by switching to BT from the Jag but at least I can manually start it on the app and it works.
Arland Green
Aug 11, 2025 08:26 AM
Autobahn kid
Jan 2, 2022 06:02 AM
X2 Jag
Sep 13, 2007 09:41 AM
04Xtype
Jul 20, 2007 10:35 PM
nineball
Oct 6, 2006 08:52 PM
