XJ ( X351 ) 2009 - 2019
Heated steering wheel upgrade
Old Oct 11, 2020 | 05:42 AM
Andycots's Avatar
Default Heated steering wheel upgrade
Hi, is there any difference in steering wheel part numbers, AW93-AW33, seen a couple around and not sure if need to get year specific, i think the part number changed 13-14, not sure, looking for a heated one as i got the poverty model, does anyone know where to look for the plug that may or may not be present, i know its behind the cowl but any idea on side colour, pin nos.
Edit- just having look around i will probably need the control module, then the module will just plug in to the plug (below the column) if fitted and connect to the slip rings at the back of the new wheel.
Andy
Old Oct 18, 2020 | 06:09 PM
eliotb's Avatar
Andy: do you know for a fact whether the x308 had the heated wheel as an option? I just got an ‘03 VDP after my ‘06 was hit by a falling tree. I loved the heated wheel in the ‘06 and dearly wish I could find one for the ‘03. Like you, I suspect if it is available I’d need a control module in addition to the wheel itself.
Thanks in advance.
Eliot
TAEUCK Goo
Mar 10, 2020 04:13 PM
carelm
Dec 31, 2019 03:23 PM
nkc1989hkjc
Nov 11, 2019 07:52 PM
Dremorg
Feb 20, 2014 04:45 PM
ftypeguy
Nov 13, 2013 01:17 PM
