XJ ( X351 ) 2009 - 2019
Help! with removal of rear coolant pipe aka Engine Coolant Outlet Flange
Old Feb 12, 2024 | 11:44 AM
djmccoy77's Avatar
Default Help! with removal of rear coolant pipe aka Engine Coolant Outlet Flange
Ok, so I had a coolant leak that I have traced to two places: 1. Heater core hose just in front of the bleed screw; and 2. The rear coolant pipe.
I am stuck with getting the rear coolant pipe out that is screwed in to the rear of the engine block. I have three of the four screws out, but the lower screw on the RH passenger side, is proving to be a formidable foe. See photo.
I have tried to buy a Topix manual but I keep getting error messages at check out.
Does anyone have any special tricks or instructions to get to that screw. I have the smallest torx ratchet that amazon sells, and I still can't even get it on there, much less have room to turn it.
TIA for the help.
Old Feb 14, 2024 | 06:47 AM
IanXF's Avatar
Old Feb 14, 2024 | 09:24 AM
djmccoy77's Avatar
Perfect. THank you
Jp129
Apr 26, 2026 08:47 AM
Gearhead01
Dec 26, 2025 09:18 AM
HippoCow
XE ( X760 )
Jul 19, 2023 09:02 PM
ufok
Jun 22, 2023 09:47 AM
lear60man
Jan 31, 2022 09:46 PM
