XJ ( X351 ) 2009 - 2019
Ignorance
Old Sep 1, 2020 | 06:18 PM
George05's Avatar
Default Ignorance
Interesting read from the brit forums for a change . no replies as usual they dont know the awnser pigs in blankets . https://www.jaguarforum.com/showthre...87#post1275887
Old Sep 1, 2020 | 09:08 PM
Stuart S's Avatar
George,
I don't know why you posted this in the X150 Forum, as it pertains to the X351 XJ with Stop-Start.
My 2013 XJ has the first version of Stop-Start with the small auxiliary battery. My CTEK MUS4.3 works perfectly to keep both batteries fully charged. I use two separate pigtails, one for each battery, and alternate attaching the CTEK between them. Here's the Stop-Start pigtails with alligator clips.
I can't address using a CTEK with the later capacitor-based Stop-Start system.
Stuart
A Moderator should move this to the X351 Forum.
Old Sep 2, 2020 | 02:58 AM
christ's Avatar
I'm sorry, but what was the question?
Old Sep 2, 2020 | 05:16 AM
No Quarter's Avatar
Perhaps least useful post ever. Subject doesn't give a clue what it is about, neither does text. Seems to be all about bashing UK forum, and then it has nothing to do with X150s.
WOT(=Waste of Time)
Old Sep 2, 2020 | 12:01 PM
scottjr1's Avatar
2012 XJ Base Portfolio V8, I need to replace the battery any suggestions as to the best battery that fits and doesn't require a mortgage also any advice on replacing does it need any special requirements
or is it an easy change? Thanks in advance, scottjr1
Old Sep 3, 2020 | 07:05 AM
Stuart S's Avatar
. .. deleted
Old Sep 3, 2020 | 07:10 AM
Stuart S's Avatar
The Pep Boys in Jupiter, Fl. Order online to get the 25% discount. Free installation.
https://www.pepboys.com/car-batterie...%205.0L%20DOHC
I have their Bosch AGM battery in my 2013 XJ and am very pleased with it. I'm not sure if you need an AGM battery because your 2012 XJ doesn't have Stop-Start. Put the same type in that came from the factory.
michaelnv
Apr 29, 2020 09:37 AM
jagstuart
US Southwest
Mar 9, 2020 08:41 AM
Jaguar Forums Editor
Jaguar Press release
Dec 6, 2016 10:28 AM
Translator
Dec 14, 2012 01:00 PM
