XJ ( X351 ) 2009 - 2019
Infotainment screen gone white
Old Sep 24, 2022 | 01:14 AM
armaan__0807's Avatar
Default Infotainment screen gone white
I have a jaguar XJL X351 2012 , the infotainment screen has gone completely white the touch screen works on the zone where the options are present but it's just blank can anybody help please..
Old Sep 24, 2022 | 07:30 AM
Stuart S's Avatar
The first thing to check with any electrical problem is the battery.
How old is your battery? If it's not fully charged, that can cause all sorts of electrical glitches.
Old Sep 24, 2022 | 10:04 AM
The battery is in perfect condition I also first thought that it might be a battery fault but it's not ....... also sometimes while driving the screen might come on but again it slowly fades away to white.
Old Sep 25, 2022 | 02:11 AM
Can anybody help me on this ?
Old Sep 25, 2022 | 02:12 AM
I don't want to replace the whole infotainment screen cause I know it is working because it displays sometimes while driving should I remove and reinstall it again maybe some loose connections might be causing the problem
Old Sep 25, 2022 | 01:20 PM
clubairth1's Avatar
Community Influencer
Does the screen stay white from start to start? Or does it work normal after starting and then fades away to white? You just need to start troubleshooting it?
I would start by removing the screen and taking a look? Maybe loose connections or maybe water/coke/coffee somehow got splashed onto the panel? I have been amazed at the circuit board damage these fluids can do.
After you get it out use the part number to find another one. Used is fine and there should be plenty out there. The screen I don't believe needs programming as I swapped mine to an Android 10" model. No programming was needed.
Can you DIY this? I ask because it looks like it is the screen.
Old Sep 26, 2022 | 07:35 AM
Ok I will try that day I will update you soon mate .....
needanswers
Aug 28, 2023 09:12 AM
Crobertrod
Nov 1, 2021 06:43 PM
Buckingham
Oct 11, 2021 05:13 PM
Peter Allen
Jan 14, 2020 10:17 AM
lsbrodsky
Nov 28, 2016 11:33 AM
