XJ ( X351 ) 2009 - 2019
Intermediate Steering Shaft Joints
Old Jun 3, 2025 | 08:49 PM
JaguarXJL15's Avatar
Default Intermediate Steering Shaft Joints
I removed the bolts, but the joint won’t come apart—the joints are rusted. The plan is to spray some WD-40, place a flathead screwdriver into the side opening, and tap it with a hammer.
I’m trying to remove the engine mount, but the steering shaft needs to be moved out of the way first.
Old Jun 4, 2025 | 10:47 AM
NBCat's Avatar
WD-40 is not a penetrating lubricant. It's for water displacement, thus the WD.
Use a product such as PB Blaster to penetrate the corrosion.
Old Jun 4, 2025 | 11:54 AM
clubairth1's Avatar
Community Influencer
Does it come off that way? Maybe the rack needs to drop down so it will pull off?
Old Mar 3, 2026 | 05:18 PM
BrokenXJ8's Avatar
I get this an old thread but I had too unbolt the rack and let it hang and hit where the shaft goes onto the splines with a hammer and a flathead in the joint too help separate it from the splines
Old Mar 4, 2026 | 07:28 AM
clubairth1's Avatar
Thanks for coming back with that great bit of advice! Simple and to the point.
Hoffe
May 16, 2024 01:02 PM
Mad Hatter
Dec 11, 2021 11:05 AM
wouldbeowner
Aug 13, 2020 08:04 PM
benji808
Oct 9, 2019 09:29 AM
S-TYPE06
Sep 3, 2016 08:10 AM
