XJ ( X351 ) 2009 - 2019
Louder exhaust for XJR 2016
Old Sep 18, 2016 | 09:26 AM
msfaml's Avatar
Default Louder exhaust for XJR 2016
I have on order a XJR and would like to make the exhaust louder. Please can someone advise me the best way to do this or recommend a company for this.
Old Sep 18, 2016 | 05:44 PM
Thermo's Avatar
Veteran: Navy
msfaml, you can always go the way of say a Mina exhaust system. It will add a little bit of volume without getting obnoxious or getting a drone inside the car.
If you are after the "I'm a muscle car" sound, then you are looking custom. From there, you can get a shop to do what many refer to as a "cat-back" setup. In short, they are going to remove all the piping from the catalytic converters back. From there, they will run new piping. This will remove the resonator and the factory mufflers. You will want to install a cross-over pipe (a 30 degree x-pipe should do what you are after) with say a 40 or 50 series muffler (keep things legal, yet give you maximum flow and lots of volume under hard acceleration).
The one word of caution that I will give you is that opening up the exhaust on the newer cars can cause issues with the O2 sensors, leading to check engine lights. So, as you are talking with local shops, ensure that if they cause a light to come on, they will make the necessary changes to get rid of the light at no additional cost.
Old Sep 19, 2016 | 04:03 AM
L80ous's Avatar
The standard exhaust sounds great, and if your into putting after market loud exhausts on stuff you've bought the wrong car mate
X308XJR
Oct 5, 2016 08:13 PM
mark campbell
Sep 25, 2016 06:38 AM
XJR-Guy
Sep 16, 2016 04:24 PM
Skivenous
Sep 13, 2016 09:19 PM
jackra_1
Sep 12, 2016 12:45 PM
