XJ ( X351 ) 2009 - 2019
Low battery Warning Message
Old Feb 24, 2022 | 04:20 PM
Historical's Avatar
Default Low battery Warning Message
Replaced the main Battery in the trunk and in my key fob and I’m still getting this message..
Thoughts please..
Thank you.
Old Feb 24, 2022 | 04:32 PM
rothwell's Avatar
My 2011 does this if I just leave a door open for a few minutes. I have read where all of them do this due to the heavy load of electronics that are active. I think that message was Jaguar's catch all preventative measure and a CYA about the excessive draining that's going on. But I am still kinda new to this car so others may have more educated opinions.
Thoughts please..
Thank you.
Old Feb 24, 2022 | 06:30 PM
sov211's Avatar
You have replaced the main battery....but clearly, it is still not at full voltage or you would not be getting this message. Did you charge the battery fully *before* installing it? New batteries are almost NEVER fully charged on installation, regardless of what the counter-person tells you (I have been through this...). And unless you do daily long runs the battery may never get fully charged. Do you have a CTEK or similar battery maintainer? these cars depend on full battery voltage all the time to power the myriad modules.
Old Feb 24, 2022 | 07:01 PM
NBCat's Avatar
+1 on using a battery maintainer when the vehicle is idle for extended periods. A 'new' battery is often on the shelf of the parts house for several months and is not fully charged.
Use a voltmeter to read the battery voltage across the terminals with the ignition in the OFF position. There should be a minimum of 12.6 volts showing on the voltmeter. If not, charge the battery for three to five hours at 2 to 5 amps.
Old Feb 24, 2022 | 07:43 PM
Historical's Avatar
Originally Posted by sov211
You have replaced the main battery....but clearly, it is still not at full voltage or you would not be getting this message. Did you charge the battery fully *before* installing it? New batteries are almost NEVER fully charged on installation, regardless of what the counter-person teslls you (I have been through this...). And unless you do daily long runs the battery may never get fully charged. Do you have a CTEK or similar battery maintainer? these cars depend on full battery voltage all the time to power the myriad modules.
I did not fully charge the battery when first purchased and have not driven much since. However I’m taking this on a 4 hour trip over the weekend and hopefully that will do the trick.
thanks for the advise.
Old Feb 24, 2022 | 07:47 PM
Historical's Avatar
I will definitely do this,
Thank you
Old Feb 25, 2022 | 12:19 PM
parnelli's Avatar
A long trip will definitely help a lot.
mine was better after I replaced battery and then took a long trip in the car. Three hours in each direction to go see my parents. All was good afterwards. I’m guessing after that three hour trip you will be fine too
Old Feb 25, 2022 | 01:56 PM
sov211's Avatar
Then it is very clear that there is nothing wrong with the Jag other than that it is not used enough! The vaule of keeping the car on a good battery maintainer (CTEK is a favoured brand) is that your battery is fully charged always, and that eliminates irritating and often worrying symptoms. In addition the life of the battery is significantly prolonged and the alternator has a much easier and longer life too.
Dogbreath!
Oct 13, 2022 03:19 PM
fredpribyl
XF (X260)
Jan 23, 2021 03:40 PM
MidLifeinTN
Oct 18, 2019 06:53 PM
bocatrip
Dec 26, 2017 06:25 PM
