XJ ( X351 ) 2009 - 2019
lower control arm
Old Oct 16, 2025 | 10:47 AM
JaguarXJL15's Avatar
Default lower control arm
I’m hearing a clunking noise from the passenger side front wheel whenever I drive over speed bumps or rough roads. I had it inspected, and the mechanic said the issue is likely the lower control arm on that side.
Before I schedule the repair, I wanted to ask should I replace both lower control arms (driver and passenger sides) at the same time, or is it fine to just replace the one that’s worn out for now?
Old Oct 16, 2025 | 01:15 PM
Vasara's Avatar
Front lower control arms, so called banana arms, does not be very expensive and very easy and fast to replace, so i always have been replaced them as a pair.
You need 4-wheel aligment after change.
Old Oct 16, 2025 | 02:07 PM
[QUOTE=Vasara;2877878]Front lower control arms, so called banana arms, does not be very expensive and very easy and fast to replace, so i always have been replaced them as a pair.
You need 4-wheel aligment after change.[/QUOTE.
when you say not very expensive do you mean OEM or aftermarket? Did you replace them yourself ? Do you need special tools?
Old Oct 17, 2025 | 11:28 AM
Vasara's Avatar
[QUOTE=JaguarXJL15;2877891]
OEM is made by Lemförder (part of ZF) and these are well available from various part shops. Yes. Been changed them many times on mine. (i have more than 200t Miles on odo and occosionally track use eats them) No special tools needed. Need to remove wheel and engine undercover. If i remember right: 15mm and 14mm socket for outer and 18mm and 20mm for inner bolts. Inner one have an adjust. Mark the location before removing, but still worth to have 4-wheel adjustment afterwards.
Old Oct 17, 2025 | 03:08 PM
[QUOTE=Vasara;2878050]
Can you confirm if the control arms differ between AWD and RWD models?Can we replace just the ball joint rather than the entire control arm? What’s the trade-off? Is there a specific advantage to installing a full control arm assembly when only the ball joint has failed?
Old Oct 18, 2025 | 08:08 AM
leadfoot4's Avatar
[QUOTE=JaguarXJL15;2878092]
It isn't just the ball joint that wears, the bushings that the arm pivots on, also wear out.
Old Oct 18, 2025 | 09:42 AM
clubairth1's Avatar
Community Influencer
Rarely the ball joint. Those banana arms have fluid filled bushings and are directional too.
I would just think of them as a normal wear item as Vasara posted. Thankfully they are available and at decent prices.
When you get the part number always check with Jaguar using the last 6 digits of your VIN. Everything is done by the VIN as many running changes were made.
Can you post what the part number is to help the next guy?
Old Oct 20, 2025 | 12:24 PM
Dealership wants $500.00 each do you know any website that ships to Canada?
Old Oct 20, 2025 | 02:18 PM
NBCat's Avatar
Have you looked at Rock Auto? They have prices in $CAD and show suspension part for X351 MY2015.
Old Oct 20, 2025 | 03:48 PM
Vasara's Avatar
Not sure if its same part on 4WD, but i highly think it is.
These are OEM numbers. Try search on eBay. Should come quite many results.
AW933C256AD, AW93-3C256-AE, AW933C256AF, C2D49933, C2D6343
(same part fit both sides)
Old Oct 22, 2025 | 07:59 AM
leadfoot4's Avatar
......... What’s the trade-off? Is there a specific advantage to installing a full control arm assembly when only the ball joint has failed?
I'm just "spitballin" here, but if I recall correctly, the arms are cast aluminum. If so, it's a distinct possibility that you could deform the arm's ID where the b/j resides, if you don't press the b/j in squarely. In that case, you'd have a b/j that doesn't fit snugly, which will be an issue, big time. AND you'll have wasted your money on just the b/j, when you have to buy an a-arm with a b/j installed, to replace the deformed a-arm........
Old Oct 23, 2025 | 11:28 AM
Freddy J's Avatar
Just a price posting FYI. My private mechanic charged me $255 each for the banana arms and $191 labor to install them.
Old Oct 23, 2025 | 12:18 PM
I bought two used ones off eBay for $80 each. I plan to install them myself when I change the rotors just two bolts each, so it should be pretty straightforward.
Old Oct 23, 2025 | 12:52 PM
Vasara's Avatar
I am afraid you wasted your money. Inner bushes wear approx 70-90t miles and new OEM ones cost about 150USD directly from ZF channel.. (most autopart shops)
High change is that 2nd hand ones have already inner bushes weared out. -> Inner bushes have small fluid chambers and these chambers start to leak ech other making it soft. Cant see it outside.
Thet are easy and fast to change, but need 4-whee aligment after change.
Old Oct 23, 2025 | 02:37 PM
I’ll take my chances and see what happens. Hopefully, they last a few years. I couldn’t find the AWD ones anywhere only the RWD versions are available.
Old Oct 23, 2025 | 03:55 PM
wombat's Avatar
OEM Part# C2P24862, Be warned, that changes like the weather forecast!
Partsgeek, are selling them for $165 for a pair.
https://www.partsgeek.com/k58b7tc-ja...RoCR2oQAvD_BwE
Or the Lemforder (OEM) for $170ea
wombat
Old Oct 23, 2025 | 04:24 PM
wombat
Do You Ship Internationally?
We do not ship outside the United States. We only ship to the Continental 48 states. On some products shipped by air freight we can ship to Alaska and Hawaii. We do not ship to Canada, Guam, Puerto Rico, or to any international destination. We also do not ship to freight forwarding companies or hotels.
Old Oct 23, 2025 | 05:36 PM
wombat's Avatar
XJL15,
I'm more than happy for you to have them shipped to me, and then I can forward them to you?
wombat
Old Oct 23, 2025 | 06:12 PM
Which ones are for $165 ? Aftermarket ? Name?
Old Oct 24, 2025 | 09:50 AM
Vasara's Avatar
Hi,
Check this. They ship to Canada and you can choose the price in CAD$ from top header
(OEM part) https://alvadi.fi/en/item/lemfoerder-39715-01
Not the cheapest price i found, but 3pcs on stock and will ship to Canada.
