XJ ( X351 ) 2009 - 2019
MAF sensor plug
Old Dec 4, 2021 | 12:23 PM
Jjdejd's Avatar
Default MAF sensor plug
Trying to change my engine filters and can’t seem to figure out how to disconnect the sensor connector so I can remove the cover. I see a small white plastic tab on the back but can’t figure out how it comes apart. Thanks
Old Dec 5, 2021 | 12:16 PM
12jagmark's Avatar
You don't need to disconnect or remove them to get to the filters. You just need to remove the cover from the lower half & move it out of the way to access the filter & vacuum out the lower half. The MAF sensors can stay connected.
I don't even recall if I disconnect the intake pipe from the filter cover for that.
Old Dec 5, 2021 | 02:06 PM
Jjdejd's Avatar
JagXK82001
Jun 16, 2019 11:58 AM
jczaban
Oct 30, 2018 03:59 PM
tnts4
Aug 3, 2015 09:25 AM
princemarko
May 30, 2013 12:44 PM
Mayor111
Oct 13, 2010 07:03 AM
