XJ ( X351 ) 2009 - 2019
Making sure I get the timing right
Old Dec 29, 2020 | 09:26 PM
amlarson2001's Avatar
Default Making sure I get the timing right
Anyone know exactly how to set the timing on the 5.0 supercharged engine? 2012 XJ. I replaced my driver cylinder head and now I am trying to get the cams and timing in correct time. Any advice would be great. I have the workshop manual but it is confusing to me. I think the crank has to be in the 6 o'clock position for the driver side and 9 o'clock for the drivers?? I know the cams have to be in a certain spot as well for each side as well. The cams are currently off the heads. I have watched many videos and none of them show how to put the cams on the head then get the timing correct.
Old Dec 30, 2020 | 04:51 PM
ricardoa1's Avatar
Do you have the needed tools?
Old Dec 30, 2020 | 06:10 PM
Yes
Old Dec 31, 2020 | 06:34 AM
Rummy636's Avatar
Did you put the lock tool where the crank sensor goes? That should put you at basic timing for the crank. Then all you have to do is set the cams using the hold down tool and colored chain links.
a1lry
Oct 19, 2020 07:02 AM
OUScooby
Dec 9, 2018 07:43 PM
Thang Nguyen
Jun 18, 2017 10:30 AM
nitrolouie2142
Sep 5, 2015 01:55 PM
Benhamtroll
Sep 22, 2011 06:05 AM
